Silverfish
Silverfish
I will tell you that this image was a ton of work. I was almost going to toss the whole data set. But then I thought about my problem, and about how the stacking algorithms work. That's when I changed my approach, and the resulting image turned out much more promising. At this point I still had to deal with a very dirty specimen. What followed was over 3 hours in Photoshop to clean up and enhance the image. My eyes hurt, I am dizzy and I am tired. But first I'll share my endevours with you.
The image consists of 341 images taken at 5micro intervals. The total depth of field is around 1.7mm. The horizontal field of view is around 2.24mm.
The setup:
The image was taken with a Mitty 10x on a Canon EF 200/2.8L II lens with a Canon EOS 7D Mark II APS-C crop sensor camera. Camera settings were ISO160, 1/200sec, f/8 (I forgot to open up the "tube" lens), mirror lockup with a 2 second delay. Images were captured as RAW and converted to TIFFs using Canon's Digital Photo Professional software package.
The light source was a single Canon 580EX II speedlite located on camera left (8 o'clock position when looking down) fired through a Styrofoam dixie cup diffuser at 1/32 power. The effective shutter speed is around 1/7500 sec.
I used a white piece of foam as my background. By changing the relative position to the flash I can control it's brightness.
Eureka moment:
At first I stacked all 341 images in one pass using both the PMAX and DMAP options. This is where I did not like how the image looked. PMAX was too grainy and contrasty, and DMAP had too many HUGE halos to edit out. That is when I realized what I needed to change. I created 49 DMAP slabs, which were then PMAX stacked. No noise, no contrast changes, and almost no halos.
This was followed by lots of cloning and healing. A lot of these touch ups were done while viewing the image at 200-400% magnification. Towards the end I was not as careful and got a little rammy.
Without any further ado, here is the final image followed up the before image.
After:
Before:
Thanks for looking. Now to hit the sack.
Cheer!S
The setup:
Eureka moment:
After:
Before:
Cheer!S
The final image is superb.
Best regards
Jörgen Hellberg
Best regards
Jörgen Hellberg
Looks like one of those stacks where each image gives you, apparently, nothing at all!
It's come out well. May I steal it as an excellent portrayal of one of nature's poorer eyes?
One has to wonder what sort of an image the beast has to work with.
11 pixels or 11 images? I should be able to look it up
Thanks zzffnn.
I totally agree, but not necessarily is that always the case. Sometimes I get lucky and an image required minimal work, or no matter how much effort I put into an image, it will always be garbage. I've thrown out days worth of work in the past.
It's best to start with a clean, well preserved subject. I haven't gotten into cleaning, preserving, rehydrating, or chemically repairing my subjects. I guess I reply on photo editing to take care of some of theses things.
You are welcome.chuong nguyen wrote:Thanks for sharing. To do it right = hard work.
I feel your pain ! but in this case the end result is definitely worth it.
When you say those pics are "before" and "after", do you mean before and after post processing or is one the straight stack and one the slabbed then stacked result ?
What software do you use to do your slabbing ?
I try and freeze my subjects as soon as possible after capture (none of that picking dead stuff up off the floor!) and photograph them straight out of the freezer (or at least as soon as they have thawed out which is about 2 minutes here in the Tropics!)
Andy
Andy
