www.photomacrography.net :: View topic - 2017 "High Magnification" Macro Setup (Automated)
Goto page 1, 2  Next
Sharks
PostPosted: Mon Feb 13, 2017 7:58 am    Post subject: 2017 "High Magnification" Macro Setup (Automated) Reply with quote
This is the new setup i used to take high magnification macro photographs. The set is built directly on the "WeMacro" automatic rail system. I still can not test it fully, but compared to StackShot price-performance ratio is very high and at 10x does not have problems.
2017-Set-2 by Can Tunçer, on Flickr
2017-Set-3 by Can Tunçer, on Flickr
2017-Set-4 by Can Tunçer, on Flickr
2017-Set-5 by Can Tunçer, on Flickr
2017-Set-6 by Can Tunçer, on Flickr
2017-Set-7 by Can Tunçer, on Flickr
2017-Set-8 by Can Tunçer, on Flickr
2017-Set-9 by Can Tunçer, on Flickr
2017-Set-10 by Can Tunçer, on Flickr
2017-Set-11 by Can Tunçer, on Flickr
2017-Set-12 by Can Tunçer, on Flickr
2017-Set-13 by Can Tunçer, on Flickr
2017-Set-14 by Can Tunçer, on Flickr
2017-Set-15 by Can Tunçer, on Flickr
2017-Set-16 by Can Tunçer, on Flickr
2017-Set-17 by Can Tunçer, on Flickr
Edit AdminCR This thread is added to Charles' List Here
http://500px.com/-Can-
http://www.flickr.com/photos/-can-/
Vish_007
PostPosted: Mon Feb 13, 2017 12:05 pm    Post subject: High Magnification" Macro Setup (Automated) Reply with quote
Great setup - just curious, what is the material you are using to cover the base board ?
Thanks,
Vishnu
Sharks
PostPosted: Tue Feb 14, 2017 4:29 am    Post subject: Re: High Magnification" Macro Setup (Automated) Reply with quote
Thanks,
I use cheap carbon fiber vinyl Smile
Sharks
PostPosted: Tue Feb 14, 2017 4:30 am    Post subject: Reply with quote
BTW;
https://youtu.be/xXdAT-rRa0o
https://youtu.be/Jh92tJXQbV4
abpho
PostPosted: Tue Feb 14, 2017 5:54 am    Post subject: Reply with quote
Sleek setup Sharks.
Sharks
PostPosted: Tue Feb 14, 2017 6:07 am    Post subject: Reply with quote
Thanks Smile
PostPosted: Tue Feb 14, 2017 7:29 am    Post subject: Reply with quote
Sharks,
Beautiful work!! You might consider replacing the "cone" adapter with a flat one. The cone type can cause some minor vignetting. With William's WeMacro and the Stackshot focus rail I've found using a simple cheap off-axis loading really helps, especially at high magnifications.
http://www.photomacrography.net/forum/viewtopic.php?t=32361&postdays=0&postorder=asc&start=0
As you've found diffusing the LED lamps is a good idea, many different options here with all sorts of things like cups, foam, tissue paper, wrapping and so on. Also moving the diffuser with the lens or fixing it are areas worth experimenting, but that's halve the fun doing the experimenting!!
Very nice setup.
billjanes1
PostPosted: Tue Feb 14, 2017 7:47 am    Post subject: Re: 2017 "High Magnification" Macro Setup (Automat Reply with quote
Thanks for a very informative post with great pictures. What brand is your 4 way focusing rail? On looking on e-bay I see many similar items for around US$30, but have no idea of their quality.
Bill
PostPosted: Tue Feb 14, 2017 7:56 am    Post subject: Reply with quote
Bill,
Think this is directly from WeMacro. Another higher performance option is the iShoot 4 way that was posted here a few weeks ago, this look like a very well built dual axis rail.
Sharks
PostPosted: Tue Feb 14, 2017 12:14 pm    Post subject: Re: 2017 "High Magnification" Macro Setup (Automat Reply with quote
Bill
Thanks
I use it for this. But you can find it cheaper Smile
http://www.ebay.com/itm/4-way-Macro-Focusing-Rail-Slider-Tripod-Bracket-uk-seller-/251486949347?hash=item3a8dca4fe3:g:UaUAAMXQydtTMwu2
Sharks
PostPosted: Tue Feb 14, 2017 12:15 pm    Post subject: Reply with quote
mawyatt wrote:
Sharks,
Very nice setup.
Thanks for advice Smile
Sharks
PostPosted: Sun Feb 19, 2017 12:25 pm    Post subject: Reply with quote
Here's the first photo:
http://www.photomacrography.net/forum/viewtopic.php?t=33336
microman
PostPosted: Sun Feb 26, 2017 4:12 am    Post subject: Reply with quote
Very clean build ! Nice to see someone else using the Wemacro.
I got it myself but have not used it yet as i miss some parts like a sturdy base and som rigg för specimen for and a camera.. Optical breadboards seems way to expensive considering freight and VAT so searching for alternatives..
Looking at your first photo it seems to perform very well.
My setup is simular, hopefully i will get nice results like you !
Probably will copy your plastic cup diffuser setup Smile
Do you run the Wemacro with distance or number of steps ?
Hope you dont mind posting a picture of mine not so finished rig.
(sorry for the crappy lightning, snapshot with borrowed point and shoot)
Sharks
PostPosted: Wed Mar 01, 2017 12:02 pm    Post subject: Reply with quote
Thanks Smile
I use "number of steps" mode all the time. With this mode, I can visually adjust the shooting.
The plastic cup is one of the best diffusers Very Happy
Sharks
PostPosted: Wed Mar 01, 2017 12:04 pm    Post subject: Reply with quote
Sharks wrote:
mawyatt wrote:
Sharks,
Very nice setup.
BTW this tactic really works. Thanks again Smile
Goto page 1, 2  Next
Page 1 of 2
