www.photomacrography.net :: View topic - First signs of spring
Joco
PostPosted: Mon Feb 06, 2017 10:54 am    Post subject: First signs of spring Reply with quote
Even if a cold period is expected later this week, spring will come!
(panorama of 3 times image stack, taken with A7R2, Novoflex Balpro1 with Proshift+, Zeiss 100mm F4 (for Contax bellows))
snowdrops by Hans van den Bosch, on Flickr
Beatsy
PostPosted: Mon Feb 06, 2017 11:18 am    Post subject: Reply with quote
Lovely image. The stacking and stitching gives it a convincing medium-format look too. Very nice.
Joco
PostPosted: Tue Feb 07, 2017 9:59 am    Post subject: Reply with quote
Thanks Beatsy,
Using these tools (soft- and hardware) takes time and practice, but it is rewarding.
PostPosted: Tue Feb 07, 2017 11:32 am    Post subject: Reply with quote
Very nice. I really like these intimate small landscapes.
Are you shifting the camera, with the lens fixed, or are you shifting the lens and keeping the camera fixed, or moving the whole thing using a nodal rail? In the out-of-focus background it looks like some items may be doubled or ghosted, but maybe it is just coincidence, or due to wind. If it is not due to wind moving things between stacks, it could perhaps be avoided by keeping the lens fixed and shifting the camera, if your lens has big enough coverage. That's what I do and it works well.
www.loujost.com
abpho
PostPosted: Tue Feb 07, 2017 7:16 pm    Post subject: Reply with quote
Nice work. Image looks great.
Joco
PostPosted: Thu Feb 09, 2017 8:29 am    Post subject: Reply with quote
Thanks Lou and abpho,
In this setup the lens is fixed and the camera shifts. The lens appears to have plenty of coverage for the 10mm shift left and right (44mm).
There are some odd patterns in the background, but I checked and they are present in each single shot (of a stack, which then was stitched). So they are 'natural'.
Btw one of the nice things about stacking is the ability to select the nicest background from a series and paint it in :-)
PostPosted: Thu Feb 09, 2017 9:21 am    Post subject: Reply with quote
Thanks for checking that. Very nice work.
www.loujost.com
Joco
PostPosted: Thu Feb 09, 2017 10:10 am    Post subject: Reply with quote
Hoping to go out and make more this weekend :-)
Perhaps of interest is that this was taken with a tripod's centre column reversed. This way I can get closest to the ground. Having the camera and bellows upside down is not ideal but surprisingly doable.
vitikin
PostPosted: Tue Jun 13, 2017 9:21 am    Post subject: Reply with quote
Very nice pic! Do you guys think the Proshift+ functionality can be replicated with the shift function of the Nikon PB-4 bellows? (for this particular application)
PostPosted: Tue Jun 13, 2017 10:37 am    Post subject: Reply with quote
No, the wrong end moves unless you reverse it. You'd want the entrance pupil to stay stationary, I think?
It would be cheaper and more flexible to buy a cheap bellows unit and cut through the rail, so you can put the ends where you want.
davholla
PostPosted: Fri Jun 16, 2017 7:51 am    Post subject: Reply with quote
very nice photos/
MacroLens
PostPosted: Sun Jul 09, 2017 1:45 pm    Post subject: Re: First signs of spring Reply with quote
Nice picture! One day maybe I will capture something like this.
