www.photomacrography.net :: View topic - Dabbling with fluorescence on a budget
Goto page Previous  1, 2, 3, 4, 5, 6  Next
PostPosted: Thu Feb 02, 2017 7:51 am    Post subject: Reply with quote
Chris, theoretically you can diffuse and de-cohere a laser beam by shining it through a colloidal suspension like milk.
www.loujost.com
PostPosted: Thu Feb 02, 2017 9:34 am    Post subject: Reply with quote
Might milk not impart its own colours?
PostPosted: Thu Feb 02, 2017 9:49 am    Post subject: Reply with quote
Not unless it flouresces; a monochromatic beam can't change color otherwise.
www.loujost.com
PostPosted: Thu Feb 02, 2017 11:20 am    Post subject: Reply with quote
Certainly but it might fluoresce! And the milk might "go off".
Perhaps gelatin, or grey paint.
A tank of liquid might absorb too much UV, too?
jcb
PostPosted: Thu Feb 02, 2017 11:26 am    Post subject: Reply with quote
@Johan : here you are.
Some theory first :
    the blue line is the transmission of the blue Lee 721 filter
    the red one the transmission of the Heliopan red R25 filter
    the green solid lines are the wavelengths that excite the chlorophylle
    the dotted green lines the luminescence wavelengths
As you see, no light passes through both filters superimposed.
The setup is basic. Having a white background helps to identify possible problems : if you see the background in the picture you are not photographing luminescence...
Here is the result (Gloiocladia_repens).
harisA
PostPosted: Thu Feb 02, 2017 11:31 am    Post subject: Reply with quote
This is a photo of the nichia led.
From the following link:
http://www.nichia.co.jp/en/product/uvled.html#NVSU333A
the only that matches is NCSU276A u365 at the middle of the page
typical optical power 780mw at 500ma.This is a yield of aprox 35%.Rather amazing i would say.
PostPosted: Thu Feb 02, 2017 12:08 pm    Post subject: Reply with quote
Chris, I don't know about gelatin. The idea is to have biggish diffractors moving around rapidly (relative to exposure time) in water.
www.loujost.com
PostPosted: Thu Feb 02, 2017 12:35 pm    Post subject: Reply with quote
Here is everything anyone would ever want to know (and more!) about using milk to reduce laser speckle patterns below the threshhold of human vision:
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=5&cad=rja&uact=8&ved=0ahUKEwj7nsHGkPLRAhUH92MKHR7vDpoQFgg8MAQ&url=http%3A%2F%2Fwww.ksp.kit.edu%2Fdownload%2F1000012434&usg=AFQjCNHOD3V5ZyqfQBPrCK1jqN5zOM_iBQ&sig2=cQ-Sw7j6oW9LAu4j8vZLpA
See Chapter 7. Diluted whole milk is best.
www.loujost.com
PostPosted: Sun Feb 05, 2017 5:02 am    Post subject: Reply with quote
Has to be homogenised. apparently!
I'm aware milk, gelatin, and Dettol are used, it's the spectral behaviour I queried.
The article doesn't mention fluorescense. Best would be to try it. Also UV may get absorbed somewhere.
I did find (P88)
Quote:
“Tamron TT18” objective which has a focal length of 18 mm and a working distance of 9.7 cm.
Hmmm!
PostPosted: Sun Feb 05, 2017 5:48 am    Post subject: Reply with quote
The laser was informative - I read, that in discussion of chlorophyll spectra
fluorescence spectra are invariate, and the same spectrum will be obtained regardless of which wavelengths are used for excitation:
I don't think that's entirely true, particularly in terms of amplitude, but with that in mind, these pop up in the first few Google hits::
and
and
Therefore, "about 405nm" leds are useful, because they're short without being too dangerous.
They provide spectral separation for either
filtering out the excitation colour from the light reflecting off the subject, or
filtering out the emission colour from the light hitting the specimen.
Chlorophyll in living plants, doesn't have exactly the same spectrum as in solution (such as ethanol).
Also, in the plant, there is a quenching effect. After first exposure to the excitation, the level of emission drops (Kautsky curve).
johan
PostPosted: Sun Feb 05, 2017 7:11 am    Post subject: Reply with quote
Thanks, very interesting!
PostPosted: Sun Feb 05, 2017 10:06 am    Post subject: Reply with quote
As you can see in the graphs (and my very limited experience agrees) the best red fluorescence of chlorophyll can be obtained around 450nm, a royal blue 450-455nm Cree XT-E is my most adequate light excitation source for it.
UV has the big advantage of providing blue fluorescence of cell walls like for example at the delightful Jacek's last images here:
http://www.photomacrography.net/forum/viewtopic.php?t=33177
PostPosted: Sun Feb 05, 2017 11:43 am    Post subject: Reply with quote
Good point, Pau - with Charles' image here, too http://www.photomacrography.net/forum/viewtopic.php?p=204608#204608 .
Next question, If we use 365nm to excite, is a 420nm long pass filter better than say a 400nm?
What is it in the walls which fluoresces blue, and at what wavelength? Something over 450nm I would guess -?
PostPosted: Sun Feb 05, 2017 12:40 pm    Post subject: Reply with quote
The devil is in the details, in principle 400nm or 420nm emission filters will work equally well for blue emission with 365nm excitation IF you actually use excitation radiation no longer than 400nm and the filter is perfect.
If you use the adequate excitation filter as I do with my filter cubes it is but in Charles setup without excitation filter the violet tail of the LED emission can obscure fluorescence, so the longer emission filter is much more adequate.
I've just ordered a Nichia UV NVSU233A-D1 365nm. When received and mounted I will be able to test it, at the moment my UV LEDs aren't adequate for this test.
This is a table fom a paper I downloaded*
https://www.google.ca/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&cad=rja&uact=8&ved=0ahUKEwi_-seu2_nRAhXExYMKHUFRDeQQFggjMAE&url=https%3A%2F%2Fwww.insti-fluor.com%2Fcst%2FCSTFluorescenceCourse34.pdf&usg=AFQjCNHFDqgYsWkDOOXjmFzVvfOCZrBx7g
So likely that blue fluorescence comes from cutin or lignin, more likely from cutin in epidermic cells
Cellulose is not fluorescent at this wavelength
http://chemistry.stackexchange.com/questions/9713/why-is-filter-paper-fluorescent
enricosavazzi
PostPosted: Sun Feb 05, 2017 12:55 pm    Post subject: Re: Dabbling with fluorescence on a budget Reply with quote
Charles Krebs wrote:
When I came across some relatively inexpensive flashlights with Nichia 365nm UV LEDs I decided to give it a try. These are the flashlights:
(picture)
They were purchased from this site:
http://www.gearbest.com/led-flashlights/pp_277704.html
I just ordered two of these because they are extremely cheap (right now 50% discount according to the web site, although this seems to be the same for many other items on the site) compared to the MTE UV torches that probably use the same or similar LEDs (I think I paid about 250 US$ for one a few years ago). If they turn out to have a comparable UV emission, these new ones are a real bargain. In fact, they are even cheaper than the retail price for one of these LEDs from some online EU sources.
Once they arrive, I can make a direct comparison of the two torch models.
Page 2 of 6
