https://www.nightsea.com/products/stere ... e-adapter/
https://www.youtube.com/watch?v=_oGXbXY9MU0
When I came across some relatively inexpensive flashlights with Nichia 365nm UV LEDs I decided to give it a try. These are the flashlights:
They were purchased from this site:
http://www.gearbest.com/led-flashlights/pp_277704.html
I liked the fact that these used rechargeable 18650 Lithium ion batteries, as I have some of these and they can power a light like this for a good long photo session.
The other piece I needed was a longpass or "barrier filter". This was purchased from Thorlabs here:
https://www.thorlabs.com/newgrouppage9. ... oup_id=999
I purchased both a FGL420 and a FGL435. So far I have only used the FGL420.
The filter was placed in the filter drawer above the objectives as indicated by the blue arrow below.
The flashlight is held by a small articulating arm. (I use mini Arca type clamps on all my articulated arms). The long thin shape of the light allows it to be positioned close to the subject.
I have a regular white light directed on the subject from the other side. I set up the shot using the white light. I also set up the automated stack start and end points with the white light. When I am ready to go I shut off the white light and turn on the UV. This is all new territory for me but the first couple of efforts seems to show that this can be a very viable approach. (And my cost for the light and filter was less than $60).
First shots (and some additional discussion) here: http://www.photomacrography.net/forum/v ... hp?t=33112
My wife tells me I worry about too many things
http://www.safetyglassesusa.com/
Maybe all this is overdoing the concern. I don't know, but I really don't care. It is not much effort to protect your eyesight.
Pau had asked which Nichia LED this is. I can't be certain but I believe is is the "NVSU233A U365" seen on this page:
http://www.nichia.co.jp/en/product/uvled.html
You can see a violet color from the LED. I think this is supposed to be the spectral output:
I am using the LED flashlight without an excitation filter. Based on the graph above and the detailed specifications of the FGL420 it looks like I might get away without using one. If I determine that I am cutting it too close I'll try either the FGL435 longpass "barrier" or use a filter on the light (from Ebay seller bjomejag) that sharply blocks anything longer than 390nm.
