Orange fire shrimp in my aquarium
dack9
Post by dack9 »
The length is about 1 cm.
leonardturner
Post by leonardturner »
Colorful creatures--did you use electronic flash?
MarkSturtevant
Post by MarkSturtevant »
Pretty! I would be curious to learn how you take good pictures thru glass. You clearly have the hang of it.
Mark Sturtevant
Dept. of Still Waters
dack9
Post by dack9 »
leonardturner,
Electronic? I do not know, I used standard external flash )
MarkSturtevant,
thank you! No any secrets. I clear the glass from the both sides and hold the camera on one axis with the shrimp.
davholla
Post by davholla »
Very good - the first is the best.
dack9
Post by dack9 »
davholla,
thank you very much.
pontop
Post by pontop »
A good way to avoid reflections in the glas is using a rubber hood and keep it against the glas. The rubber lets you change the angle of the camera and still seal out the light reflections of a flash or other light sources outside the aquarium.
dack9
Post by dack9 »
pontop wrote:A good way to avoid reflections in the glas is using a rubber hood and keep it against the glas. The rubber lets you change the angle of the camera and still seal out the light reflections of a flash or other light sources outside the aquarium.
Thank you for info.
