www.photomacrography.net :: View topic - Specimen Holder
Specimen Holder
Goto page 1, 2  Next
houstontx
PostPosted: Sat Jan 14, 2017 5:49 pm    Post subject: Specimen Holder Reply with quote
Where to buy or how to make a DIY specimen holder? I am currently using a piece of stiff wire which works but is a pain to get into place easily.
Thanks,
C.Seno
PostPosted: Mon Jan 16, 2017 7:50 pm    Post subject: Reply with quote
I have many different sized needles for varying insect size. I just dip the needle tip in super glue and stick it in the specimen. The needle can be stuck into clay and maneuvered easily.
https://www.flickr.com/photos/cseno/
houstontx
PostPosted: Tue Jan 17, 2017 11:02 am    Post subject: Reply with quote
Clay i never thought of that! I have some so I will try this out thank you!
Xanthocryptus
PostPosted: Mon Mar 27, 2017 8:04 pm    Post subject: Reply with quote
I have a 'Microscope stage' from Bioquip - really its a nifty little specimen holder that allows you to rotate and reposition the specimen easily.
JH
PostPosted: Mon Apr 03, 2017 12:06 pm    Post subject: Reply with quote
This link might be of some interest.
http://www.photomacrography.net/forum/viewtopic.php?p=132806#132806
Regards Jörgen
Jörgen Hellberg, my webbsite www.hphoto.se
microman
PostPosted: Fri Apr 07, 2017 8:05 am    Post subject: Reply with quote
These look pretty cool. I used a much more basic model when i began.
https://www.amazon.com/QuadHands-Helping-Hands-Third-Soldering/dp/B00GIKVP5K
MAvisdavis
PostPosted: Thu Sep 07, 2017 7:51 am    Post subject: Reply with quote
I modified a similar solder station. The great thing about this one is I can alter the length of the arms Smile
(First post by the way) Hey guys Smile
Olympusman
PostPosted: Thu Sep 14, 2017 9:10 am    Post subject: Specimen holder Reply with quote
I use pipe cleaners with a pin glued on the end and then glue the pin to the insect. Far cheaper than a goniometer and just as effective. Microscopists/macroscopists are known for their patience, so this is just another day at the office.
PostPosted: Thu Sep 14, 2017 10:18 am    Post subject: Reply with quote
Welcome MAvis !
You can post up to 1024 square, with a 300kB size limit, by the way. Medium quality Jpeg should be fine.
MAvisdavis
PostPosted: Tue Sep 26, 2017 7:44 am    Post subject: Reply with quote
ChrisR wrote:
Welcome MAvis !
Thanks ChrisR Smile
concon
PostPosted: Tue Sep 26, 2017 11:08 am    Post subject: Reply with quote
Welcome man! I use those same arms to hold my backgrounds.
I personally use an alligator clip on an xyr stage on a precision lab jack. I find flexy arms are not reliable enough at high magnifications; something with precise controls saves headaches and time (definitely time).
Harald
PostPosted: Wed Sep 27, 2017 12:59 pm    Post subject: Reply with quote
Hi there houstontx,
I only use clay. Easy to get in any toystore.
This is useful for pinned insects. Position it just the way you want.
Kind Regards
Harald
Lier Fotoklubb / NSFF
AFIAP / CPS
BGF / GMV
PostPosted: Wed Sep 27, 2017 2:19 pm    Post subject: Reply with quote
Here's a couple holders.
MJKZZ
http://www.mjkzz.com/product-page/flexible-specimen-holder
Wemacro
http://www.wemacro.com/?product=specimen-holder
Deanimator
PostPosted: Thu Sep 28, 2017 11:45 am    Post subject: Reply with quote
Harald wrote:
Hi there houstontx,
Depending upon the subject, I use clay or a DIY third hand made using stiff electrical wire a small carpenter's clamp and an alligator clip.
The third hand works well with light subjects, not much heavier than a 3/8" washer. There's too much movement with heavier objects.
For heavier objects, I prop them up with the clay molded to stay out of the picture. I haven't tried using it to hold a needle yet.
Yawns
PostPosted: Sat Sep 30, 2017 7:09 am    Post subject: Reply with quote
I use a stage rather than a flexible arm .. I find it easier this way .. very easy to place a background...
the stage allows me to lay several diffusers very easy
for a specimen holder I use a ping-pong ball, cut in 2 halves, filled with plasticine (to make it heavy) and taped back to original position ... the ball over a metal ring ... this is a very chaeap way to have tilt and rotation virtually in any direction and makes tunning the insect positioning very easy
Goto page 1, 2  Next
Page 1 of 2
