www.photomacrography.net :: View topic - installing a darkfield condenser
Crusty
PostPosted: Sat Jan 14, 2017 2:10 pm    Post subject: installing a darkfield condenser Reply with quote
I recently bought a Olympus BHTU-BH2 on Ebay which came with a small box marked "darkfield". The microscope works well and I assume the condenser (DCD 0.92-0.8) does too. The problem is that I have no idea how to install it. No help is forthcoming from the internet. Does anyone have any suggestions?
thanks
houstontx
PostPosted: Sat Jan 14, 2017 5:27 pm    Post subject: Reply with quote
Does it have the dovetail circular bottom? Can you lower to condenser to its lowest position, slide in the darkfield condenser and then secure it with the small set screw and then move it back up to position?
Ive never installed one myself though...
PostPosted: Sun Jan 15, 2017 12:37 pm    Post subject: Reply with quote
It's very simple, you just need to remove one condenser and put the other in place, there are two Olympus main condenser mounting systems but I think that all BH2 do use the base dovetail mount referred by houstontx. Once mounted you must place it at the right height and perform a careful centering to get good dark field.
At http://www.alanwood.net/photography/olympus/downloads.html you can download the manual of your microscope
Crusty
PostPosted: Fri Jan 27, 2017 6:25 pm    Post subject: Reply with quote
Thanks to you both. I was able to get the darkfield condenser up and running.
