www.photomacrography.net :: View topic - Arachnoidiscus ehrenbergii
Post new topic   Reply to topic    www.photomacrography.net Forum Index -> Administrator's Appreciation Gallery...Photography Through the Microscope
sushidelic
PostPosted: Sat Jan 14, 2017 2:03 pm    Post subject: Arachnoidiscus ehrenbergii Reply with quote
Hello,
here's another diatom I like a lot. Extern lighting and this time the SPlan Apo 60x/1.4.
The most interesting thing was, when I examined the center closely, it was revealing some dots with defined lit and dark side, that each measured around 300nm in diameter. Should be close to the resolution limit of classic light microscopy?
Best regards,
Michael
PS: I hope with my recent post I didn't kill my whole quota of pics for january, and it's okay to post another one...
zzffnn
PostPosted: Sat Jan 14, 2017 3:20 pm    Post subject: Reply with quote
Very nice image!
But exactly how did you provide "external light" for an oil immersion 60x NA 1.4 objective? Isn't the working distance of than objective less than 0.3 mm?
I found a working distance of 2mm very challenging for external light. I cannot envision how external light can pass through WD of less than 0.3mm. Are you using fiber optic coupled to microscope slide? Even that, you would need to stop down objective to much less than NA 1.4 (to around NA 1.1).
Would you please kindly show a photo of your light/microscope arrangement?
PostPosted: Sat Jan 14, 2017 3:40 pm    Post subject: Reply with quote
Magnificent!
I'm also interested in your illumination technique, are you illuminating the immersion oil or the slide glass itself?
PS: don't worry, they are just two images (actually one) in a day
Wink
sushidelic
PostPosted: Sun Jan 15, 2017 8:40 am    Post subject: Reply with quote
Just two quick pics from the setup (weekend is kids' time...).
I'll explain it a bit more later!
Best regards,
Michael
PostPosted: Sun Jan 15, 2017 12:06 pm    Post subject: Reply with quote
Brilliantly simple. Very Happy Your images are brilliant too BTW. Very Happy I have done something similar with the diffusing cylinder and incident lights, I used a section cut from a breakfast health drink bottle ('Actimel' in the UK). But this was for a low power subject. I'm sure other forum members have done something similar. What I'm astounded by is that it gives enough light for high power objectives and even oil immersion. I have to try it. What sort of exposure times are you getting with the X63 objective for example? Also what camera are you using?
I'm also very impressed with how clean your stacks are. Whether it's another benefit of the lighting, I don't know, but I often find problems of halos and smearing (I call it 'melting' because that's what it looks like) of detail with stacking high power images of high contrast subjects like diatoms and radiolaria.
The example radiolaria and diatoms you have photographed are really nice examples as well. Are these mounts you have made yourself or carefully selected examples from commercial prepared mounts?
PostPosted: Sun Jan 15, 2017 12:26 pm    Post subject: Reply with quote
I concur with all what Dave says. So simple and effective and nobody has published it before Shocked
sushidelic
PostPosted: Sun Jan 15, 2017 1:05 pm    Post subject: Reply with quote
I actually have no clue, where the light passes in the end. Sure it goes through the slide, refracted, reflected on the condensor, oil, whereever... It's true, that even with only the 10x apo I'm unable to shed light on top of the eye of a daphnia, so it is basically a very oblique illumination, but due to the diffusor, it is still somewhat soft light. That helps revealing detail and for stacking Smile.
The diatoms are from a bunch of "stray" slides I bought on ebay, among those random diatoms you always find some that are well oriented and in good shape. The guy who made them embedded them in zrax, with literally no dirt at all.
Camera was a Nikon D800 with an NFK 1.67, and expoure times where roughly 5-10 seconds with ISO 100. Those long exposure times are annoying as shooting stacks takes ages, but at the same time, shutter shock is no issue at all.
Best regards,
Michael
zzffnn
PostPosted: Sun Jan 15, 2017 1:33 pm    Post subject: Reply with quote
Thank you. I have never tried 5-10 second exposure. That explained most of it.
PostPosted: Sun Jan 15, 2017 1:41 pm    Post subject: Reply with quote
SUPER!!!!
PostPosted: Sun Jan 15, 2017 2:00 pm    Post subject: Reply with quote
Super !
What you have on a glass slide to obtain black background?
Olympusman
PostPosted: Sun Jan 15, 2017 2:17 pm    Post subject: Diatom Reply with quote
Nice image interesting ligthing technique.
sushidelic
PostPosted: Mon Jan 16, 2017 2:27 am    Post subject: Reply with quote
Thanks a lot for you replies!
With an NA of 1.4, it was impossible to obtain a black background. Unfortunately, the 60x Apo doesn't have an diafragm, so i had to use the full resolution, and the source image looks kinda weird DIC style. Fortunately, most specimen have a clear border, so with careful masking the black BG is added in Photoshop. If you use apertures below 1, it can look similar to DF with a near black BG right on the source image.
Best regards,
Michael
billben74
PostPosted: Wed Jan 18, 2017 3:11 pm    Post subject: Reply with quote
Fantastic shot. The lighting works very well. I love it.
Really interesting technique. As I am sure many will, this is definately on my to do list.
abpho
PostPosted: Wed Feb 01, 2017 7:42 pm    Post subject: Reply with quote
Wow. Amazing. Looks like a maze. Very hypnotic. Congratulations on making the picture of the month too. Applause
sushidelic
PostPosted: Fri Feb 03, 2017 1:52 am    Post subject: Reply with quote
Thanks a lot! 1000x thanks a lot!
When i decided to get the Vanox back in october last year, I wasn't really sure wether this is just an expensive crazy idea out of a midlife mood.
But now i have found something that really adds to my life, and the results are encouraging me to keep experimenting and discussing, and shooting Smile.
Well, thanks again!
Best regards,
Michael
Post new topic   Reply to topic    www.photomacrography.net Forum Index -> Administrator's Appreciation Gallery...Photography Through the Microscope All times are GMT - 7 Hours
