www.photomacrography.net :: View topic - Drosera capensis glands at 4x
Davids
PostPosted: Fri Dec 30, 2016 12:14 pm    Post subject: Drosera capensis glands at 4x Reply with quote
Still playing around with this Nikon Apo Plan 4x NA 0.20. Shot using a Fuji x-t1, nikon pb-6 bellows at ~160mm.
These are digestive glands of Drosera capensis 'red form'. The fact that the trichome stalks are red and semi-transparent makes lighting slightly tricky!
Saul
PostPosted: Fri Dec 30, 2016 1:57 pm    Post subject: Reply with quote
Nice composition & light
Saul
PostPosted: Fri Dec 30, 2016 4:31 pm    Post subject: Reply with quote
Very nice!
Hard to really judge from this size image but it would appear that the 4X is providing excellent images (as would be expected!)
Davids
PostPosted: Sat Dec 31, 2016 8:24 am    Post subject: Reply with quote
Thanks Charles! Yes, this appears to be quite a lovely objective, especially brand new for $150!
I'd like to put together some shots for the forum to "test" the objective, but I'm embarrassingly clueless as to the procedure, even when it comes to doing a 100% crop or being able to post the image at the best resolution given the forum size limits. But, I'll keep playing around with it.
PostPosted: Sat Dec 31, 2016 8:39 am    Post subject: Reply with quote
Quote:
a 100% crop
Yes it's an ambiguous description!
Simply, crop 1024 pixels wide from your original , unsharpened 5000 x 3500 or whatever-it-was image, and post that onto the forum.
If you make sure the memory it uses is something a bit under the forum limit of 300kB, it should be fine.
The subject does matter - specular highlights and extreme contrast can be misleading, so this image might not be the most appropriate.
Sumguy01
PostPosted: Sun Jan 01, 2017 9:52 am    Post subject: Reply with quote
Applause Very nice.
Thanks for sharing.
