www.photomacrography.net :: View topic - Resource Limit Is Reached?
Goto page 1, 2  Next
NicoVB
PostPosted: Thu Oct 20, 2016 6:38 am    Post subject: Resource Limit Is Reached? Reply with quote
Hi admins,
I often experience following error when browsing the forum.
It's a blank page with following text
The website is temporarily unable to service your request as it exceeded resource limit. Please try again later.
Can you solve this?
When you make the most fantastic discovery, a lot of people want a piece of it...
PostPosted: Thu Oct 20, 2016 1:58 pm    Post subject: Reply with quote
I also often get that, even if just a couple of tabs are open.
www.loujost.com
PostPosted: Thu Oct 20, 2016 2:47 pm    Post subject: Reply with quote
It has nothing to do with several tabs open at your browser (with a slow computer this can be problematic but doesn't induce this error). I often open lots of tabs at once.
It happens time to time, right now it's becoming pretty annoying.
This is due to some kind of server malfunction. Rik has contacted with them several times without a clear solution.
We can do little at the moment to fix it, sorry.
PostPosted: Thu Oct 20, 2016 2:51 pm    Post subject: Reply with quote
Ironically when I clicked to read Pau's new comment, I got a message instead: "Resource limit is reached".
www.loujost.com
johan
PostPosted: Thu Oct 20, 2016 5:31 pm    Post subject: Reply with quote
The hostpapa server that this site is hosted on is hitting some resource limits set by hostpapa. These are typically RAM, CPU or something else. Often these are set on servers where a lot of sites share the same server, in order that usage of one doesn't impact on other sites on the same server. I actually mailed the host myself a couple of years ago as an annoyed user but got nowhere. Unfortunately forums are quite resource and space intensive. Rik could try moving host but with this relatively old version of this forum software, a migration and possible upgrade like that is a whole barrel of unfun that I strongly suspect he'd rather avoid Smile
NicoVB
PostPosted: Fri Oct 21, 2016 6:59 am    Post subject: Reply with quote
I don't agree with that and why is this error occuring?
You only host txt and pictures here, that is not very intensive...
Do you have a php.ini in your root dir of the forum?
Is so plz add this line to it:
Code:
memory_limit = 512M
If not, plz create it
That is indeed a hussle, but it can be done...
PostPosted: Fri Oct 21, 2016 9:44 pm    Post subject: Reply with quote
Nonetheless, Johan's description is accurate.
The message reflects throttling at the level of the Apache web server, caused by a large number of expensive requests arriving too quickly together.
When it occurs, our admin panels always show an unusually large number of Guest logins from what appear to be robots of one sort or another.
The standard indexing robots are not so bad. Although they make lots of requests, the requests that they make are apparently fairly inexpensive and do not cause problems. For example just before I started to type this reply, the admin panel showed that in the preceding few minutes there had been 3 registered users and 163 guest logins, most of those from Google. The forum was running fine at that time.
In contrast, last night I logged on to find that the forum was hitting resource limits, and when I checked the status, I found that some unknown robot was doing nothing except trying to check user Profiles. This is a not an effective thing for a Guest robot to do, because nobody except logged-in users are permitted to look at profiles. In response to the request, the forum presents a login screen. I have no idea where the conversation with the robot goes from there, other than apparently consuming quite a few resources for no value. I blocked the offending IP address at the level of .htaccess, and the problem went away.
That was an unusual circumstance. More typically we find a robot apparently clicking buttons at random. (Guest logins trying to Post are good indicators.) Some of them may be ill-designed indexing robots; others we think are corporate firewalls that are proactively looking for malware on sites visited by users who live behind the firewall.
In any case, these instances of unusually high demand from robots end up acting as sort of unintended denial-of-service attacks. It doesn't take much load to do that because the forum is only hosted on an inexpensive shared server account.
Yes, we could probably solve the problem by just moving the forum to a higher class server. That would not be hugely difficult, or hugely expensive, but to date the annoyance has not been worth the trouble and expense to do it. That may change in the future, of course.
dmillard
PostPosted: Sat Oct 22, 2016 4:22 am    Post subject: Reply with quote
Rik -
Thanks for explaining this issue so clearly. And thank you very much for administering this informative, inspiring site where civil discourse is the norm, rather than the exception.
David
PostPosted: Sat Oct 22, 2016 4:53 am    Post subject: Reply with quote
Yes, I second that. This is the most productive, civil, and interesting photography forum I have ever encountered. Hats off to you Rik and your co-mods! These resource limit problems are slightly annoying but not common, and the far bigger danger is that this forum should become a burden to you timewise to the point where you get tired of it. A few minor annoyances are a small price to pay. I'm sure we all understand the voluntary nature of the administration of this forum and can accept its limitations.
www.loujost.com
pierre
PostPosted: Sun Oct 23, 2016 12:31 am    Post subject: Resource Limit Is Reached? Reply with quote
Hello Rik,
Many thanks for those clear explanations.
Regards
Pierre
NicoVB
PostPosted: Sun Oct 23, 2016 4:18 am    Post subject: Reply with quote
@rjlittlefield
Good thing you found out that it's a robot causing the problem.
I'm not sure if blocking the ip is a good permanent solution, it may work for now, but if the ip of that robot changes you hit the same problem.
I'm sure you know that you can add some lines to the robot.txt file and block them there, if not, read the following.
http://www.robotstxt.org/robotstxt.html
And thx for looking into the problem.
johan
PostPosted: Sun Oct 23, 2016 5:32 am    Post subject: Reply with quote
robots.txt is thoroughly useless for blocking spambots Smile.
PostPosted: Sun Oct 23, 2016 6:07 am    Post subject: Reply with quote
Indeed. robots.txt is a handy tool for communicating intent to friendly cooperative robots. It exerts no control whatsoever over unfriendly robots, which simply ignore it.
abpho
PostPosted: Mon Mar 06, 2017 10:35 am    Post subject: Reply with quote
Is this what drove the user count up to 1193 on May 8 2011 at precisely 8:24pm? I've always wondered about HUGE that number.
GaryB
PostPosted: Mon Mar 06, 2017 8:54 pm    Post subject: Reply with quote
I had the same resource issue but I treat it just like my wifi dropping out at home, it'll pass and I'll do something else until it's back up again.
To add to others comments, thank you Rik for a great site. Very Happy
Goto page 1, 2  Next
Page 1 of 2
