Fly & LED ring
Moderators: Chris S., Pau, rjlittlefield, ChrisR
Post Reply
Adalbert
Fly & LED ring
Post by Adalbert »
Hello everyone,
I have just tested my LED ring.
http://www.ebay.com/itm/AmScope-144-LED ... SwnipWaL0V
mid. pos. / 150 * 2 seconds
BTW, the photograph has been taken by Olympus MSPlan 50x / 0.55 and CANON EF 70-200L
BR, Adi
BugEZ
Post by BugEZ »
Interesting. Was there some lag between photos? The second stack makes me suspect the eye may have dried a bit. I like the first photo a bit better because the lenses are shiny.
Can you share how the ring light was positioned? What was the objective's working distance? The clarity at that mag is impressive! Your technique is excellent!
Keith
Adalbert
Post by Adalbert »
Hello Keith,
I am very glad that you like it.
- No, there were only some minutes between the stacking sessions.
- The WD of this Olympus is 8.1mm.
- The ring was mounted directly on the microscope lens. So, the lens was in the middle of the ring.
BR, Adi
Impressive detail. I'm not sure how this is working though. The ring light you link to is for the front of a stereomicroscope and has quite a wide diameter fixing, but from the magnification and resolution, it looks as though your images are taken with a microscope objective, which would have a much smaller diameter. Have you made some kind of adaption collar for the objective?
Adalbert
Post by Adalbert »
Hello Cactusdave,
Yes, I have changed the screws (to 5 cm long)
and used the mount of my medical diffuser.
BR, Adi
BugEZ
Post by BugEZ »
Thanks for the info and the link to the diffuser setup.
The results are quite good and at very high magnification. The close coupling between actuator and bug provides good stability. Very important with LED exposures.
K
Aloha
David Sykes
Post by David Sykes »
If the working distance is just 13mm and the leds are pointing straight ahead, surely hardly any light reaches the subject ?
Adalbert
Post by Adalbert »
Hello David,
The ring is 30mm thick and microscope lens is 40mm long.
BR, Adi
David Sykes wrote:If the working distance is just 13mm and the leds are pointing straight ahead, surely hardly any light reaches the subject ?
First, the pictures demonstrate that light is illuminating well
Second, the LEDs are pointing inwards, clearly shown at the last picture, sadly the diffuser if used is not pictured
Adalbert
Post by Adalbert »
Hello Pau,
The diffuser for this LED-ring has been made of paper:
BR, Adi
Nice diffuser, I like DIY inexpensive stuff :D
Post Reply
