www.photomacrography.net :: View topic - Del-Tron LRS3-1 horizontal field/studio setup
Goto page Previous  1, 2
Saul
PostPosted: Fri Apr 28, 2017 6:47 am    Post subject: Reply with quote
lonepal wrote:
...If I can use same controller for both 200 step and 400 step motors...
Yes, you can use it for both motors. Step settings will be different
Saul
lonepal
PostPosted: Tue May 02, 2017 10:57 am    Post subject: Reply with quote
I have returned Smile
I found two types of 400 steppers;
http://www.ebay.com/itm/Reprap-3D-Printer-Nema17-0-9-Wantai-Stepper-Motor-4200g-cm-56oz-in-42BYGHM809-/281921203310?hash=item41a3d02c6e:g:Y7UAAOSwMmBVxEc7
http://www.ebay.com/itm/CNC-Nema17-for-2-4A-4200g-cm-48mm-length-0-9-Wantai-42BYGHM810-Stepper-Motor-/311656933303?hash=item48903367b7:g:z-EAAOSwZQRYfueU
One of them is 1.7A and the other is 2.4A
I know the PSU of the Wemacro rail is 2A.
Which one can I use? Using the 2.4A motor may damage the controller?
Can anyone advice me to use one of above 400 steppers and explain why?
Thanks.
Regards.
Omer
Saul
PostPosted: Tue May 02, 2017 11:58 am    Post subject: Reply with quote
lonepal wrote:
...Which one can I use? Using the 2.4A motor may damage the controller?
Thanks.
Did you contact williamG from WeMacro directly ?
And:
http://www.photomacrography.net/forum/viewtopic.php?p=195995#195995
Saul
JohnKoerner
PostPosted: Sun Sep 10, 2017 6:11 pm    Post subject: Reply with quote
You have a terrific field setup.
Where can I buy that battery case? (I already have a RRS Groundpod).
Blog | Facebook | Flickr | Wildlife Database
PostPosted: Sun Sep 10, 2017 6:23 pm    Post subject: Reply with quote
Get battery package from William at Wemacro.com, not sure about the case though. This pack will power the Wemacro rail all day long with proper batteries, and also works with Stackshot controller and focus rail (has same connector and voltage).
Make sure you get the right batteries, tabbed 18650 batteries will not fit, only flat tab-less end fits. You need to get these elsewhere, William doesn't sell them.
Also, not all 18650s are alike, anything advertising something like 4000 or 5000maH is a fake. Read not Tmart!!
Good source for legit Samsung 18650 batteries and charger (Nitecore) is
IMRbatteries.com
JohnKoerner
PostPosted: Sun Sep 10, 2017 6:31 pm    Post subject: Reply with quote
IMRbatteries.com
Much obliged, good sir
PostPosted: Sun Sep 10, 2017 6:43 pm    Post subject: Reply with quote
IMRbatteries.com
Your welcome.
William has a really nice handy field bag for the battery package. The battery package design is interesting in that it appears to be a switch-mode regulated output at 12 volts with 3 18650 batteries.
Mine held to 12.0 volts output as I ran the Wemcaro rail back and forth full length until I got tired doing this. Well more work than I can imagine any stacking full field day session taking. Impressive performance IMO.
Smokedaddy
PostPosted: Sun Sep 10, 2017 7:27 pm    Post subject: Reply with quote
Sweet!
Saul
PostPosted: Tue Sep 12, 2017 12:13 pm    Post subject: Reply with quote
... or you can use:
http://www.ebay.com/itm/Battery-Box-3-18650-Li-ion-Series-Holder-ON-OFF-Switch-5V-USB-12V-5-5MM-DC-Plug/282143059556?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l2649
Saul
PostPosted: Tue Sep 12, 2017 2:15 pm    Post subject: Reply with quote
Saul wrote:
... or you can use:
Saul,
That looks just like the one William at Wemacro sells, but without charger. Good find!!
Saul
PostPosted: Wed Sep 13, 2017 6:26 am    Post subject: Reply with quote
Thanks Mike. I had an idea to feed not only Wemacro controls but flash also (in the field, of course. For home I'm using separate PS for flashes), wasn't sure for how long it would be enough for both. So kept this item in the ebay wish list.
BTW, now for the flash I'm using holder/case with 2x18650 plus converter down to 6v
Saul
Saul
PostPosted: Wed Feb 21, 2018 2:27 pm    Post subject: Reply with quote
Del-Tron Black edition :
Del-Tron Red edition goes for sale.
http://www.photomacrography.net/forum/viewtopic.php?p=227796#227796
No difference between these two setups, no improvement (worked very well, nothing to improve Smile ), only plastic color and hardware
Saul
ray_parkhurst
PostPosted: Wed Feb 21, 2018 2:35 pm    Post subject: Reply with quote
Where did the knob on dual-shaft motor come from? Is the motor shaft 5mm?
Saul
PostPosted: Wed Feb 21, 2018 3:00 pm    Post subject: Reply with quote
Correct, shaft is 5mm
Knob - item is not available from this seller, but you can try to find it from other sellers. Shaft is 6mm, so I had to use little bit of electrical tape ...
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F132230321524
Edit:
Item 162355307913, but expensive - I paid 3x less
Saul
Page 2 of 2
