Wemacro stacking rail
I've been evaluating the WeMacro rail for a few days, but I think I have found a problem. Whether in tethered mode via EOS utility, or standalone, if the camera is in Live View the shutter release does not work. I'm not familiar with how the StackShot works, but I assume it indeed can release the shutter when in Live View, otherwise the EFSC function would not work, and mirror slap would be an issue. Would someone using StackShot please confirm? I do see this note on the WeMacro software setting page:
"Notice:The shutter signal may be affected if you are using camera software such as Canon’s EOS utility or Nikon’s CameraControlPro Liveview on PC.You can turn off Liveview in software before run the rail."
I think what this implies is that you must turn off Live View before shooting. If that is true then it is a showstopper for me as I count on Live View with continuous lighting for all my shots.
Interesting - Pentax doesn't do tethering for its APSC bodies which is why I didn't spot it in my review - sorry
But, on a better note, if you're not in tethered mode then liveview stacking works just fine. At least it has on my Pentax.
No worries johan, caveat emptor et al.
I do have happy news however...my first try untethered also yielded no trigger with Live View. I just tried again and indeed it did trigger properly as long as EOS Utility was not active. This will force me to connect via HDMI, which seems easy but the connector is not a standard HDMI connector so I need to go get an adapter...
ahhh, so you're just outputting the screen to another screen via HDMI, rather than outputting and controlling? That's what I always do - though I don't keep LV on cause it eats batteries like crazy
My normal method is using Helicon Remote, tethered via USB. Live View is passed over USB. If I do single shots, I use EOS Utility, also passing Live View over USB. Since WeMacro seems USB-phobic, I will need to try Live View over HDMI instead. Live View indeed eats batteries fast, but I have little choice when doing continuous lighting.johan wrote:ahhh, so you're just outputting the screen to another screen via HDMI, rather than outputting and controlling? That's what I always do - though I don't keep LV on cause it eats batteries like crazy
I can't speak for Ray but I don't - for me I just like to be able to set start and end points on a big screen. Then I switch liveview off.
That is an interesting point.....However perhaps this is an issue for MFT sensors and/or large stacks. I find noise is an issue with my Oly OMD-EM10II but not the Sony A7rMIILou Jost wrote:Johan, I also turn Live View off after setting endpoints. It can be important to turn Live View off during a stack. Sensor noise depends on temperature and using Live View continuously makes the sensor hotter.
As I use a different camera not sure this comment is applicable. I had a similar issue with A7rMII. My preferred Shutter release for stackshot,cable) uses the Micro USB port on the camera.... but that rules out live view.....I tried using the HMDI to get live view..... but it didn't work (as Noted already may be just a sony issue). I use Capture 9 pro for Sony. I am awaiting the arrival of a USB splitter to see if I can get a work-around. When I do use live view ( not often) I revert to the IR shutter release however it is not reliable.I will need to try Live View over HDMI instead.
This is a huge issue with the sony A7series cameras. I purchased an AC adapter which has a dummy battery that feeds the power to the Camera. This allows allows the camera to be mains powered and frees up the USB port for the shutter release or live view.Live View indeed eats batteries fast, but I have little choice when doing continuous lighting.
Still learning,
Yes, noise is certainly more of an issue with MFT sensors. One way to minimize it on these sensors is to use hi-res mode, which almost completely eliminates it, but this slows a stack tremendously. External power supplies for the camera are necessary then.
There is also the problem of heat shut-down of flashes in deep stacks, if one is not using continuous light. I am modifying my Yongnuos to make them stay cool longer. Will report on that later in a different thread.
Hiray_parkhurst wrote:I don't need to see it, I just want EFSC to be active. With Canon cameras that only happens when Live View is active. If I turn off Live View, then the mirror will cycle before each shot. Not good with continuous light.Lou Jost wrote:Once you start a stack, why do you need to see what it is doing?
Ray
I had sent you a message,but at that time I'm not aware of what is EFSC.
We will find a camare with this function to test it. According to this page
http://www.robertotoole.com/blog/2014/0 ... er-curtain
We figure out another way to reduce the mirror‘s vibration with continuous light.
Dear William;
I found two types of 400 steppers;
http://www.ebay.com/itm/Reprap-3D-Print ... SwMmBVxEc7
http://www.ebay.com/itm/CNC-Nema17-for- ... SwZQRYfueU
One of them is 1.7A and the other is 2.4A
I know the PSU of the Wemacro rail is 2A.
Which one can I use? Using the 2.4A motor may damage the controller?
Could you advice me to use one of above 400 steppers and explain why?
Thanks.
Thanks.
Regards.
Omer
Omer
