How to correct the aberrations?
Adalbert
Post by Adalbert »
Hello everyone,
Does anybody know if and how the aberrations can be corrected by the software (but not by any eyepiece) ?
I have just tried to remove the chromatic aberration with PS but without any success.
What about Piccure+ or Topaz Clarity ?
Enclosed you will find a photo taken with my low-cost lens:
BR, Adi
Something like this any good?
g4lab
Post by g4lab »
How did you do that? Adjust the magnification of the separate RGB channels?
JW
Post by JW »
Look s like a PS removal of cyan and magenta channels to me, as whats left behind in the strongly cyan areas is grey. Would like to take the next step and "move" the cyan and magenta pixels into their proper place in the image.
It's not what you look at that matters, it's what you see - Henry David Thoreau
:D
Not quite right, and less complicated.
Any more guesses?
MaxRockbin
Post by MaxRockbin »
To my eye... you can get to the ChrisR corrected image with:
Photoshop->Camera Raw->Lens Corrections->Color
Defringe (to taste). I think I got to this look with
Purple Amt = 5
Hue = 15/67
Green Amt =3
Hue = 29/88
Though without knowing the bug, it's hard to know whether the eye should have some blue or not. This would mostly take it out.
What's the bug?
If your pictures aren't good enough, you're not close enough. - Robert Capa
Adalbert
Post by Adalbert »
Hi MaxRockbin,
The lens corrections of the PS I have already tested :-( and this is a ladybird :-)
BR, Adi
Adalbert
Post by Adalbert »
Hello Chris,
Yes, it is a little bit better :-)
BR, Adi
This was very simple. Doesn't recover detail, but on areas of bristles etc can be OK.
Put image in Photoshop Layer 1
Copy to Layer 2
Layer 2, Filter>Gussian blur. Set amount to suit - try 3, try 30...
Layer2, set Layer mode to Color
Done
You can add a Layer mask to Layer 2. The CA will get dragged towards not grey, but the average of the area, because it's blurred.
and change its transparency
and change the colour(s).
You can derive a mask from a high-pass filtered version of the image, and use that for the "color" layer mask, to apply the effect primarily to edges.
If you've done all the CA correction you can in Raw, or in Tiff/Jpeg stacked output, and have some CA left, it can be useful.
It may not be "correct" but it's less offensive than seeing coloured edges, I think.
Edit
Same thing, but it's easier if you change the order.
Duplicate the layer, set the new layer Mode to Color
(you see nothing changed)
THEN Filter>Blur>Gaussian Blur, and you can use the slider/increment/decrement to see the effect "live"
Search words - chromatic photoshop correction fringes
Chris,
Extremely useful technique... thanks for posting this.
For whatever reason, the "standard" global CA tools that are frequently useful for regular photography are often marginally effective for some of the aberrations experienced with situations like seen here. This works surprisingly well.
MaxRockbin
That's a great idea ChrisR!
I've been doing pretty much exactly that with Zerene stacker DMap and PMax stacks - using the DMAP (maybe slightly blurred to lessen artifact effects) as a color blended layer on top of a Pmax layer.
That way you get the nicer colors (usually) of the Dmap stack on top of the Pmax (Typically sharper/less artificated) luminensce layer.
But it never occurred to me the same technique could reduce chromatic aberration fringing.
I'm not sure, but I think it was Craig Gerard who brought it to the forum :)
JH
Post by JH »
Thanks!
Very useful technique – would be nice to have in the FAQ section.
Regards Jörgen
