www.photomacrography.net :: View topic - In-camera focus bracketing with Olympus OMD M1 part 2
Goto page Previous  1, 2, 3, 4, 5, 6, 7  Next
austrokiwi1
PostPosted: Sun May 08, 2016 3:07 am    Post subject: Reply with quote
ChrisR wrote:
How depressing!
We can all think of ways to try to work it out, but giving no guide at all doesn't earn them any respect.
Does the "0.75 x dof" theory seem to work? Does it change with aperture?
I haven't really looked at it further. I think the .75 of DOF is as good a guess as any. From my observations ( not rigorous) it does seem to match up with the focus peaking highlights, the 2-3 times I tried to see what was going on.
Still learning,
Vish_007
PostPosted: Sun May 08, 2016 11:21 am    Post subject: Reply with quote
[quote="wayupnorth"]
Quote:
In order to maintain constant exposure between shots P, A & S are unsuitable so the camera should be used in manual.
Thank you,
Vishnu
elf
PostPosted: Sun May 08, 2016 11:09 pm    Post subject: Reply with quote
I'll have to disagree a little bit. I use aperture priority mode in order to maintain consistent exposures, especially when doing macro panoramas.
I think it's best to experiment when shooting in different environments.
PostPosted: Sun May 08, 2016 11:46 pm    Post subject: Reply with quote
Each one has his style and tricks, but as general advice I agree that M mode will provide the most uniform exposure between frames, of course providing that the illumination is constant.
PostPosted: Sat Jul 16, 2016 8:11 pm    Post subject: Reply with quote
I now have tested some of these lenses as tube lenses for the Mitu 10x. I can confirm that the Oly 60mm macro vignettes with this objective, but their beautiful 75mm lens does not. The field of view with the 75+Mitu is 4.6mm. This looks very good.
I've also tried the Panasonic 100-300 as a tube lens. Vignettes at all zoom settings, though at 300mm only the corners are affected. The results do not look sharp though (in the viewfinder).
www.loujost.com
pierre
PostPosted: Fri Sep 23, 2016 11:36 pm    Post subject: In-camera focus bracketing with Olympus OMD M1 part 2 Reply with quote
Dears,
A bit off line question, but since you have to take numerous pictures, you might want to lose a stack due ran-off battery.
Does the E-MD5 Mark II have a way to have permanent AC power like the Nikon or Canon using dummy batteries ?
I have search for this but failed.
Regards
Pierre
g4lab
PostPosted: Sun Sep 25, 2016 11:35 pm    Post subject: Reply with quote
The M5 mk II can be run on AC but it is an expensive addition. You have to buy a double grip outfit and second battery and the AC adapter is like $80.
But it us available. buy the time you buy all the parts you will be several hundred dollars lighter. But the camera is very reasonably priced to start with given its many talents.
elf
PostPosted: Sun Sep 25, 2016 11:54 pm    Post subject: Reply with quote
There are several models of the BLN-1 battery on thingiverse. It wouldn't be too much of a stretch to 3d print one and connect it to a 7.4V wall wart.
PostPosted: Mon Sep 26, 2016 5:54 am    Post subject: Reply with quote
I bought the power supply for the em5II. But there is no similar thing for the PEN F which has a better sensor. Do you think it would be safe to make a dummy battery and connect to a DC transformer? Voltage regulation might not be sufficiently precise.....
Alternativeluy use a dummy battery in the camera connected to a battery pack outside made of a few Oly batteries in parallel.
www.loujost.com
wayupnorth
PostPosted: Mon Sep 26, 2016 8:58 am    Post subject: Reply with quote
Surely the simplest way is to invest in a couple of spares and change batteries a bit earlier. I have 3 and would probably run out of storage first.
Pat
http://patcooper.500px.com/
www.microft.co.uk
www.antarcticimages.co.uk
www.highlandsimages.co.uk
pierre
PostPosted: Mon Sep 26, 2016 12:32 pm    Post subject: In-camera focus bracketing with Olympus OMD M1 part 2 Reply with quote
Many this for your answers & kind support.
3D print seems OK.
There is also a ready to use solution:
https://www.bhphotovideo.com/c/product/1259651-REG/tether_tools_crbln_1_relay_camera_coupler_for.html
Using DC couplers works fine on all Canon, and the Fuji camera I have used.
Regards
Pierre
PostPosted: Mon Sep 26, 2016 2:32 pm    Post subject: Reply with quote
Pierre, magnificent solution!!!! Thank you so much. This is perfect for the PEN F and solves the biggest problem of shooting deep stacks with that camera. I ordered it immediately.
www.loujost.com
elf
PostPosted: Mon Sep 26, 2016 5:02 pm    Post subject: Reply with quote
Did you order the required relay as well? https://www.bhphotovideo.com/c/product/1235872-REG/tether_tools_crups110_case_relay_camera_power.html/pageID/accessory
PostPosted: Mon Sep 26, 2016 5:08 pm    Post subject: Reply with quote
Yes I did, but thanks for making sure. I could easily have missed that.
www.loujost.com
PostPosted: Mon Sep 26, 2016 5:26 pm    Post subject: Reply with quote
A big external battery could have been another way to go. Eg here,
http://www.exprodirect.com/ex-pro-on-the-move-7600mah-rechargeable-battery-power-system-replacing-for-use-with-ex-pro-coupler-system-for-canon-nikon-and-sony-dslr-cameras..html
Though they don't do an Oly lead I expect the voltage is the same??
Be careful with external supplies.
I used a cheap one for a Canon 600D/T3i for years, then one day I plugged it in while it was switched on.
It broke the camera - beyond economical repair. I get "Error70" unless I only use the useless auto mode.
I'd like to know exactly why it broke it. It isn't difficult to limit the open circuit voltage of a power supply. I doesn't measure very high on a meter but it could be spiky.
Page 6 of 7
