www.photomacrography.net :: View topic - Broken plastic fine focus gear
Saul
PostPosted: Tue Feb 23, 2016 10:53 am    Post subject: Reply with quote
Choronzon wrote:
... a 2 micron per division travel, 200 microns per revolution fine adjustment, just like the Labophot.
So, insides are same like in the Labophot ?
Any idea what is the division travel for the Swift M3200 ?
http://www.publicsurplus.com/sms/docviewer/aucdoc/DSCN0377%5B2%5D.jpg?auc=765161&docid=5552284
Thanks !
Saul
PostPosted: Tue Feb 23, 2016 12:26 pm    Post subject: Reply with quote
I can't see any scale at this microscope side, but if present at the opposite side the numbers must refer to micrometers (at least in all microscopes I've used it does)
Saul
PostPosted: Tue Feb 23, 2016 12:31 pm    Post subject: Reply with quote
Both sides are without scales:
http://www.ebay.com/itm/Swift-M3200-Series-Microscope/121902129776
or
https://www.google.com/imgres?imgurl=http://www.publicsurplus.com/sms/docviewer/aucdoc
/DSCN0377%25255B2%25255D.jpg%253Fauc%253D765161%2526docid%253D5552284&
imgrefurl=http://www.publicsurplus.com/sms/auction/view?auc%3D765161&h=768&w=1024&tbnid=8L9MqwPvEFSurM:&
docid=t7g8NgkovMg_bM&ei=kLTMVtGLNMTkjgTixa3YAw&tbm=isch&ved=0ahUKEwjRk93x0I7LAhVEsoMKHeJiCzsQMwggKAMwAw
Saul
ray_parkhurst
PostPosted: Thu Feb 25, 2016 8:19 pm    Post subject: Reply with quote
lothman wrote:
I ordered gears (16T module 0,4 for Labophot 2 and 18T module 0,3 for Labophot 1), will drill them and offer them.
Gluing with Loctite is very easy and strong.
Verified the 64 pitch does not work, so the guts of mine must be same as Labophot1. Anxiously awaiting your making these available.
Saul
PostPosted: Thu Feb 25, 2016 8:31 pm    Post subject: Reply with quote
Agree with Ray, got mine also - very close, closer than previous ones ... but not enough Sad
Saul
lothman
PostPosted: Fri Feb 26, 2016 2:11 am    Post subject: Reply with quote
Very Happy don`t be afraid, I ordered the gears, should arrive next week.
Sumguy01
PostPosted: Sat Feb 27, 2016 8:23 am    Post subject: Reply with quote
Hi guys
Does the Optiphot 2 takes the same gear as the Labophot 2 ?
If so I am interested in a spare if available.
lothman
PostPosted: Tue Mar 01, 2016 10:06 am    Post subject: test user Reply with quote
I'm searching a Labophot-2-replacement-gear-test-user. The gears arrived and I drilled them to ø4mm. For a test user I could provide a free sample including Loctite adhesive.
As a trade-off the assembly should be foto-documented and the function should be proved.
Anybody?
regards
Lothar
P.S.: the Labophot 1 gears are low on stock, I'll receive only a few. The next batch is announced in 6 weeks.
ray_parkhurst
PostPosted: Tue Mar 01, 2016 10:13 am    Post subject: Re: test user Reply with quote
Anybody?
regards
Lothar
Sure, I'm your guy. Is 4mm correct? I need to check but I thought it was 3mm?
PostPosted: Tue Mar 01, 2016 11:31 am    Post subject: Re: test user Reply with quote
Definitely check. Would be very interesting if it's different from what's shown at http://www.photomacrography.net/forum/viewtopic.php?p=172315#172315.
lothman
PostPosted: Tue Mar 01, 2016 11:56 am    Post subject: Re: test user Reply with quote
Labophot 2, ø4mm bore, module 0.4 (bigger teeth and bigger diameter than Labophot 1), 16 teeth, outer diameter should be 7,2mm. That's what Rik's Labophot 2 had.
Labophot 1, ø3mm bore, module 0.3, 18 teeth, outer diameter 6mm, that's what my Labophot 1 had
ray_parkhurst
PostPosted: Tue Mar 01, 2016 12:18 pm    Post subject: Re: test user Reply with quote
Per earlier replies, mine is a Modular Focus block, with guts equivalent to Labophot1, so I need the 3mm bore 18 M0.3 gear. I tried a 64-pitch gear, and it was a little too large in diameter, so I believe this is correct. So I am your guy for the Labophot1 test...
ray_parkhurst
PostPosted: Tue Mar 01, 2016 2:29 pm    Post subject: Re: test user Reply with quote
Confirmed, 2.97mm.
lothman
PostPosted: Wed Mar 02, 2016 8:06 am    Post subject: Reply with quote
Sumguy01 wrote:
Hi guys
IMO yes it's the same gear, I sent you a PM.
Sumguy01
PostPosted: Fri Mar 04, 2016 9:07 pm    Post subject: Reply with quote
Maybe this will be helpful.
I found the Nikon part number for the fine focus shaft assembly for the Optiphot 2.
This is the shaft with gear installed.
P/N 2 B260-035-1
It may be a way to confirm that its the same as the Labophot 2 or any other scopes.
Does anyone have the P/N for the Labophot 2?
Page 2 of 3
