Stereo anaglyphs
Stereo anaglyphs
I want to produce a set of images for a "slideshow" loop using anaglyphs.
A teacher wants "something going on" during a school open evening.
The objects won't be very small - of the order of 10 - 40mm across. They'll be electronics components, such as transducers, parts of circuit boards, or old hard drives. They'll be back-projected onto a frosted glass room divider, about 3m across.
I have about a day to do it so would appreciate hints to shorten my learning process. I won't be able to try the projections and reshoot.
My thoughts are that I don't need high resolution as it's projected, but I'll need bold contrasty colourful images. I haven't tried taking anaglyphs before.
Will I need the image to be sharp through the depth for the anaglyph to work well, or wll it look OK if it's not all in sharp focus?
I'm thinking to use:
  • true stereo, rotating the subject 7 degrees between the two views,
    small apertures, only enough focus stacking to make the main part of the subject clear,
    relatively hard light.
I'll try Stereo Photo Maker to make the anaglyphs.
(Yes I have a box of glasses)
The screen is outlined red, the (very bright) projector is ceiling mounted just out of shot, top left.
Grotty phone pic:
Awkward situation, not being able to test & iterate.
I don't hear problems in the plan.
No, the images don't need to be sharp all the way through. But as far as you can, make sure that the same parts are sharp in both images. You won't be able to get that perfect because of the difference in viewing angles, so get as much depth as you can from stopping down rather than stacking.
Hmm. The ambient light level is bothering me. I'll make sure I have high key colourful "straight" shots too.
Well it "works" though I'll have to select colours carefully.
I'm not sure my glasses correctly match the Blue or Cyan outputs - between the two perhaps. May try Photoshopping.
The LEDs are green, and red.
My dominant eye (red lens) mostly seems to "win" throughout, though the red LED flits between black and colourless.
Not so good with primary colours, perhaps.
I tried the "Half Colo" and other options - this one is "Ghost reduced".
Auto Align seems to work well :)
The image doesn't work well for me for three reasons:
- the front plane LEDs have very different tones so they don't superimpose well because they don't seem the same object. I think that it will better if you done the same monochrome conversion for both images before converting to anaglyph
- my cardboard/plastic red-cyan glasses don't elliminate completly the undesired image, more important with the red filter.
- too much displacement (I guess)
soldevilla
Post by soldevilla »
My experience with anaglyphs is not rotating the sample, but displacing the camera approx. 6 cm. the interpupillar distance. Maybe for "near" subjects, this distance must be smaller.
And I never seen a good anaglyph in colour... Is better to convert the images to B&W and add the filter colour with your picture editor. If you need, I can search a Photoshop action that I made several years ago for to convert pairs of images in anaglyphs.
Thanks. "Gray Anaglyph" is indeed one of the options and it does look better.
You can also play with the contrast, brightness and gamma for each image.
