Thank you Lothar, the technical advice is greatly appreciated! English is easier for me than German, but google translate serves well for basic german, given short phrases.lothman wrote:Why not 100x100 instead of 50x100, the bigger 100x100 would give you stability in both directions, also better against torsion. . .
I concurr that a 100x100mm profile should be stronger, less prone to vibration, etc... although it may necesitate a heavier base plate. But I still prefer a centered slot to facilitate mounting arca compatible clamps directly to the very center of the column.
I identified this heavy 120x120mm aluminum profile by Item as a possible candidate that seems to comply with the above considerations:
QUESTION 1: Given all of the above, overall ¿what do you think of this 120x120mm profile?
On the issue of fastening the column to the base plate, it occured to me that this profile's 8 holes at the ends may serve as strong anchor points.
QUESTION 2: ¿Are bolts, between the base plate and threaded anchor points in the bottom of the column, the strongest method?
QUESTION 3: Would one reasonably expect normal steel bolts in pre-threaded holes to provide a stronger connection than "self tapping" bolts in un-threaded holes?
QUESTION 4: Given a connection of 8 anchoring bolts to base plate, would re-enforcing gussets on the sides of the column still be adviseable? (i.e L-shaped profiles bolted to the top of base plate and the column?)
