Layers of rust
Layers of rust
I ran across this scene a few days ago and thought it was interesting in several aspects. Some of those were visual, some of them not.
As the title says, this is layers of rust. I'll share the "not" aspects after somebody guesses what the rusted thing was. :(
Stereo pairs follow, crossed-eye.
Nikon D800E, Mitutoyo M Plan Apo 5X with Raynox 150 tube lens, extension slightly increased for better framing. Zerene Stacker PMax, synthetic stereo.
Edit: corrected typo, "Raynox 105" --> "Raynox 150".
abpho
Post by abpho »
Is this the thread of a screw/bolt?
It is not. This thing was completely smooth when it was new, and there were no threaded components anywhere near this.
Beatsy
Post by Beatsy »
Damascus steel blade?
I can understand Beatsy's suggestion, with the appearance of something wrought, and possibly into layers by hand folding/hammering. But it looks SO irregular that I'm suggesting it's a piece of rock/iron ore.
Beatsy, this piece was definitely not intended and never used for cutting.
ChrisR, it's definitely not a piece of rock or iron ore. Not likely to have been hand folded or hammered either, though I can't say for sure about that.
abpho
Post by abpho »
Was it a magnet? Do they even rust?
Surfaces always tend to rust in flakes, because it forms in a layer then comes off because there's a volume increase, which raises stresses.
First I read "Raynox 105" as 105mm so quite thick flakes, but Raynox 150 would be 210mm so not so thick.
Thick rust, with quite thick flakes, makes me think the layering might be related to an internal structure of the original material. Like a forged leaf spring.
I've never studied rust though, it's not good for much!
I'll go for a forging or rolled piece rather than a straight casting. The layers are sometimes called "mechanical fibering". Cast thin sections can show it too though.
I dare say it would be possible to tell the difference between something rusted in a marine (salty) environment versus dry air, or underground, etc. One for Abby Sciuto.
pontop
Post by pontop »
The inside of that old focus block you are chopping up?
BTW when looking at the stereo pairs the grayish triangular part looks like it is placed wrong. To my eyes it looks like it is floating behind everything else.
/Bo
pontop wrote:To my eyes it looks like it is floating behind everything else.
These pairs are intended for cross-eyed viewing. You must be managing to fuse them parallel. If you want to do that, then pull them into StereoPhoto Maker and press the Swap Left/Right button.
Magnet, no.
Focus block, no.
Leaf spring, no.
Forged or rolled, probably. :)
Picosvistas
Post by Picosvistas »
Old disused railway track?
Beatsy
Post by Beatsy »
A file?
Not railroad track, and not a file.
Not an antiquity, either. It is modern manufacture.
An odd fact that may also be a hint: this was a key supporting component in a piece of equipment that was fully functional and used several times daily until 3 days ago, when I replaced it for fear of imminent and catastrophic failure.
Bill Eldridge
Post by Bill Eldridge »
Is it vehicular in nature?
Not vehicular. The "catastrophic failure" would have been only a matter of the equipment falling apart in place. No injuries would have resulted, and little if any property damage. Come to think of it, the equipment probably would have continued to be functional, despite collapsing. :?
