www.photomacrography.net :: View topic - Starter leaf stomata
Walter Piorkowski
PostPosted: Sun Aug 20, 2006 9:11 pm    Post subject: Starter leaf stomata Reply with quote
My first submission.
After joining these forums I had to erase 95% of the photomicrographs from my hard drive. They just didn’t rate the quality that I see on this web site.
Here however is my first image to share, one of my favorite plant world subjects, the gas releasing valves of a leaf, the stoma. This pair from a starter leaf of an unknown plant along with the epidermal cells that surround them.
Leitz Ortholux in reflected light mode
23X W Ultropak objective
Subject submersed in water
10X Leitz Periplan GF projection eyepiece plus 1/3 Sp. Reflex lens
Canon 10D
Photoshop contrast and sharpening enhancement
Walt
PostPosted: Sun Aug 20, 2006 9:43 pm    Post subject: Reply with quote
Walt... very nice post! Good look at the stoma and a very attractive pattern and color variation in the leaf. (If I let my imagination wander I can see Teddy Roosevelt in there... spectacles and bushy mustache and all Rolling Eyes )
I take it this is a water immersion ("dipping") objective. You say "reflected light mode", but the lighting looks much better than many pictures I've seen with an "epi" type illuminator (which often look too "flat"). Was this done with an "epi" illuminator?
Have you ever looked for these on a the small duckweek leaves that are so common on ponds? I see them there often when I look for small critters... interesting and great patterns too.
Did you ever learn more about your Nikon/savart 40x situation?
PostPosted: Mon Aug 21, 2006 2:47 am    Post subject: Reply with quote
This is a great shot Walt. Very Happy I have tried in vain to get similar shots of these things.
Teddy Roosevelt Exclamation Charlie you have some imagination there but I do see what you mean. Wink
bernhardinho
PostPosted: Mon Aug 21, 2006 9:20 am    Post subject: Reply with quote
Hi Walter,
I'm a great fan of leaf stoma too. This shot is beautiful and interesting. Charles: I think Walter is talking about the leaf itself being mounted in water. But I wonder where the colors come from. Does that "reflective light" technique imply that you didn't use a thin section or pulled of the epidermis?
Bernhard
Walter Piorkowski
PostPosted: Mon Aug 21, 2006 10:21 am    Post subject: Reply with quote
Hello, Charles, Ken, Bernhard,
You are not the first to see a face in this image. It was my wife’s first comment! On a more serious side, the leaf was purple, giving it a unique color tone in the image.
Yes, the objective is a water immersion design. My specimen is mounted in a homemade mount that keeps the leaf submerged for the purpose of using it for hours, even days without it drying out. I can often watch the gas bubbles discharging from the stoma during my observation period.
I was going to describe my image setup as EPI illumination but I’m not certain as to the technical definition of EPI. With the Ortholux the light source enters the objective assembly at a 90 degree angle and is reflected down around the objective. A focusing collar allows for control of the illumination which after reflection off the subject is taken up by the objective and delivered to the eyepiece/ camera. This may be what EPI is?
My old Ortholux did not come with the reflected light source. I made up a source on my own in my workshop. I didn’t have time to build a bulb centering assembly but it has turned out to be an advantage. The off center illumination creates a side lighting affect on the surface of the subject which I can control for maximum benefit.
Yes I have observed the stoma of the duckweed and have an older image that I may post. If other forum members find the stoma of interest they may want to try the leaves of the grasses. Their stoma are a different dog bone shaped design. I am trying to capture a decent image to show the difference.
Still no solution on the Savart DIC 40X objective problem.
Walt
Walter Piorkowski
PostPosted: Mon Aug 21, 2006 7:01 pm    Post subject: Reply with quote
Bernhard,
To answer your question spcifically with this specimen there was no need to remove an epidermal layer or make a section. The stoma were fully exposed along with the epidermal cells.
Walt
