www.photomacrography.net :: View topic - Solitary wasp, interesting prey carrying adaptation, ID help
Goto page 1, 2  Next
Post new topic   Reply to topic    www.photomacrography.net Forum Index -> Macro and Close-up Archives
PostPosted: Fri May 25, 2007 4:20 pm    Post subject: Solitary wasp, interesting prey carrying adaptation, ID help Reply with quote
I have this small wasp, (about 10-12mm length) that has some very unusual adaptations for catching and carrying prey. I've not seen it before and would greatly appreciate any guidance toward some level of ID.
This small wasp has rather ornate, thin "shields" attached to a front leg segment (the femur I think). At the base of the femur is a serious looking pincer, and at the end of the front leg is one of the most elaborate claw structures I've seen. It's a little tough to "read" the picture because of the odd way the leg is jointed and shaped.
The top shot shows the features I've described. The bottom are crops that show the pincer and claw. (I hope to put these under the microscope to get more detailed shots).
PostPosted: Fri May 25, 2007 5:32 pm    Post subject: Reply with quote
What an incredible set of photos Charles. That creature is so strange. I can see exactly what you are describing and it looks like it has a very specific purpose. The closest thing I can come up with is some kind of dryinid wasp. The females are supposed to have front tarsi that are pincer like. Antennae 10 segmented, rising low on the face and not distinctly elbowed. Larvae are parasites of planthoppers, leafhoppers and treehoppers. Not 100% sure though Wink This is according to Peterson field guide to the insects. The hind wing is supposed to have a spur or what they call a jugal lobe along the lower edge near the thorax and reduced venation in the wings. Peterson shows the female with wings, all of the pictures I see on the web are wingless
PostPosted: Fri May 25, 2007 8:33 pm    Post subject: Reply with quote
What a bizarre creature! I have no idea what this is, but I surely am looking forward to finding out!
I don't feel at all comfortable about Dryinidae -- words like "raptorial forelimbs" [ref] and "chelate foretarsus" [ref] sound like a good match as words, but the pictures I can find don't look even close.
Charlie, can you tell us some more about where you found this beast? Is it one of a kind or did you find others at the same place?
And (oh yeah, I forgot for a moment that this is a photo forum Wink ) what can you share about how you shot the pictures?
Speaking of forums, have you posted this creature to BugGuide.net to see if somebody there recognizes it?
PostPosted: Fri May 25, 2007 9:25 pm    Post subject: Reply with quote
Hi Rik and Doug,
I just did these and have only posted them here. Found it by Lake Sammamish here in Issaquah (N 47.552 W 122.067). The blackberries are just starting to bloom and there are all sorts of bees and small wasps around them. This was the only insect I collected, and it was pretty small. I could just barely make out something "different" by eye, but I thought it was an attached mite or some sort of parasite. I found the interesting physiology when I put it under the low power stereo scope.
It has the "typical wasp" slender waist and black and yellow striped abdomen. It is very hard to photograph in a way that provides a good sense of the structure. In "person" under the stereo scope, is appears that the "shields" together with unusually jointed legs, pincer and claws would allow this wasp to grasp around the body of it's prey and the shields would form a nice aerodynamic cover "shell". (Note also the black and yellow coloration of the shields... much like the abdomen).
The pictures above were stacks taken with a Canon 35/2.8 Micro lens on a bellows with the Nikon D200. (The high mag double pane shot is just crops from a full frame).
I've added another shot below taken with a 50/2.8 El Nikkor reversed on the bellows. Whiffle ball lighting for all. Wink
Wink
DaveW
PostPosted: Fri May 25, 2007 10:29 pm    Post subject: Reply with quote
Those things on the legs look rather like some form of catching bag for insects, rather like a catchers mitt in baseball, or how they now provide a web between thumb and fingers on cricket wicket keepers gloves so the ball does not slip through?
Would not have thought they were air brakes.
DaveW
PostPosted: Fri May 25, 2007 10:56 pm    Post subject: Reply with quote
Fascinating critter.
I strongly encourage you to post at BugGuide.net. I just can't think of a good substitute for getting a few dozen people who care and already have their memories loaded up, to take a look at your problem.
About the images, they're beautiful stacks, of course. But I wonder, in this case, whether the high resolution stills might be supplemented with some low resolution stereo or rocking shots to better show off the unusual structure.
I think I have the structure figured out at this point, but as you suggest, it has been a bit of a struggle!
PostPosted: Fri May 25, 2007 11:25 pm    Post subject: Reply with quote
Charles, excellent images as always!
They show a male digger wasp. There used to be only one family, the Sphecidae, but there has been a split not too long ago, so you will find a familiy Crabronidae also. (Depending on publication date of literature)
Itīs the tibia that is broadened and the "boy" has these strange "forearms" to hold his "girl" in a special grip. Very Happy
This should be a male of the genus Crabro. Or a related genus of the subfamily Crabroninae.
(Note, I am not familiar with your North American fauna and havenīt got the time to check it out to make absolutely sure. But I think, now youīve got a starting point for your ID) Wink Very Happy
Best regards.
Betty
PostPosted: Sat May 26, 2007 12:58 am    Post subject: Reply with quote
Ah... Betty comes through once again! Very Happy
Very interesting. Thanks!
PostPosted: Sat May 26, 2007 2:15 am    Post subject: Reply with quote
Charles, perfect images and incredible finding! Very Happy
Betty, you worth your weight in gold for this forum! Wink
errors are welcome. Very Happy
PostPosted: Sat May 26, 2007 3:10 am    Post subject: Reply with quote
Well, it sure is a special find Charles, Beautiful and strange. I was off on my hunt for an ID. I never knew there were strange wasps like the dryinid wasps also. The segment count on the antennae did not match up either. I love the way your insects are super clean and not a hair out of place. Fantastic work Charles.
PostPosted: Sat May 26, 2007 5:53 am    Post subject: Reply with quote
Wonderful colour and extraordinarily clean detail - so much to look at - and so thought provoking too!
Thanks,
Bruce
Gordon C. Snelling
PostPosted: Sat May 26, 2007 6:35 am    Post subject: Reply with quote
Great wasp, I know it but am drawing a total blank. Definitely not a Dryinid though. Will get my dad to take a look and get his opinion.
Http://www.armyants.org
Http://www.notesfromunderground.org
PostPosted: Sat May 26, 2007 6:39 am    Post subject: Reply with quote
I don't know what it is but the first image is a killer. Awesome photograph! Surprised
Rutherford Co., Western North Carolina
"Social isolate?"
PostPosted: Sat May 26, 2007 7:46 am    Post subject: Reply with quote
Betty, many thanks for the ID!
BugGuide does have a few other pictures of these, see for example http://bugguide.net/node/view/19413/bgimage. None nearly as nice as Charlie's, of course. And it works best to search under Crabroninae -- "crabro" also picks up lots of Vespa crabro, the European Hornet.
According to the entry in BugGuide,
Quote:
His front tibia are greatly expanded into those shields so easily visible here. He covers the female's eyes with those things during mating. The plates don't blind her, but apparently filter light in such a way that she recognizes this is a male of her own species. How weird is that?
PostPosted: Sat May 26, 2007 9:23 am    Post subject: Reply with quote
Nice find Rik. Wink
Post new topic   Reply to topic    www.photomacrography.net Forum Index -> Macro and Close-up Archives All times are GMT - 7 Hours
Goto page 1, 2  Next
Page 1 of 2
