www.photomacrography.net :: View topic - Hyalodiscus rubicundus feeding on an algae
Goto page 1, 2  Next
Post new topic   Reply to topic    www.photomacrography.net Forum Index -> Administrator's Appreciation Gallery...Photography Through the Microscope
Ferry
PostPosted: Fri Nov 21, 2014 3:20 pm    Post subject: Hyalodiscus rubicundus feeding on an algae Reply with quote
The next sequence shows how a cell of Hyalotheka dissilens is attacked by Hyalodiscus rubicundus.
Hyalodiscus rubicundus is a vampyrellid amoeboid which opens cells of algae and sucks their content, hence its name.
Hyalodiscus rubicundus penetrates the mucous layer around the algae.
The amoeba reaches the cell membrane of the algae and starts to open a cell. This process lasts for about 10 minutes.
Suddenly, within seconds, a large part of the cell content moves into the amoeba. This goes fast.
The next 15 minutes Hyalodiscus pulls all the remaining pieces of the chloroplast in its cytoplasm, piece by piece.
The job is done.
Hyalodiscus moves to the neighbouring cell and the process starts again.
16 minutes later the cell is open.
When Hyalodiscus is filled with food, it builds a digestive cyst.
After some days the amoeba (left, orange spot) leaves its cyst, leaving indigestible residue behind.
Holes made by Hyalodiscus in cell walls of Hyalotheka dissilens.
www.natuurfotografie.info
www.arcella.nl
PostPosted: Fri Nov 21, 2014 3:26 pm    Post subject: Reply with quote
Ferry, what an interesting and well photographed sequence! Applause
PostPosted: Fri Nov 21, 2014 4:39 pm    Post subject: Reply with quote
Incredibly informative and well explained - thanks!
GemBro
PostPosted: Fri Nov 21, 2014 8:02 pm    Post subject: Reply with quote
Excellent shots Ferry ... brilliant sequence of events ... stills (in story board fashion) are sometimes better than video ...
I haven't ventured into Micro Photography but I could sit and watch these all day long ... very informative ...
Canon 550D(T2i) ML (Nightly Builds) | Raynox 250 | Palinar 35mm f2.8 (reversed) | EL-Nikkor 50mm f2.8 N | EL-Nikkor 50mm f4 N | EL-Nikkor 50mm f4 | Bellows | Objectives: LOMO 3.7x 0.11 : 8x 0.20 : 40x 0.65
RiG II - 'Bamboo': Olympus CH Focus Block with Inverted Arca/Swiss | Canon 430 EX (x2) | Olympus T20 flash (x2) | Youngnuo YN-622C Wireless triggers (x3) | Ikea Jansjo 3W LED Lighting (x3)
Optional Arduino based Stepper Focusing system (being built)
PostPosted: Sat Nov 22, 2014 12:40 am    Post subject: Reply with quote
wow ! Shocked
PostPosted: Sat Nov 22, 2014 1:08 am    Post subject: Reply with quote
Wow, Ferry! A story well told, very interesting and illustrative. A tour de force.
--Chris
PostPosted: Sat Nov 22, 2014 2:07 am    Post subject: Reply with quote
Fantastic explanation of this incredible sequence Shocked Wink
Arturo
www.microscopeitaly.it
vasselle
PostPosted: Sat Nov 22, 2014 3:45 am    Post subject: Reply with quote
Bonjour
Bravo cette observation qui est super intéressent car pour moi c'est la première fois que je vois ça.
Merci pour la partage.
Cordialement seb
Microscope Leitz Laborlux K
Boitier EOS 1200d
piermicro
PostPosted: Sat Nov 22, 2014 7:42 am    Post subject: Reply with quote
Very well sequence. Very interesting.
PostPosted: Sat Nov 22, 2014 7:50 am    Post subject: Reply with quote
Excellent, thanks for sharing it!
JH
PostPosted: Sat Nov 22, 2014 5:15 pm    Post subject: Reply with quote
Hi Ferry
Interesting, informative and very nice photos!
Is it the same preparate and amoeba that you have in the thirteenth picture "After some days the amoeba..." as you have in the first pictures? If it is, how do you keep the preparate fresch for such a long time.
Regards Jörgen
Olympusman
PostPosted: Sun Nov 23, 2014 8:44 am    Post subject: Sequence Reply with quote
Ferry,
Bravo! Amazing sequnce.
PostPosted: Tue Nov 25, 2014 2:42 pm    Post subject: Reply with quote
Ferry,
This is really a wonderful sequence of images. Glad you posted it!
Ferry
PostPosted: Tue Nov 25, 2014 4:11 pm    Post subject: Reply with quote
Thank you all!
@ Jörgen,
Look at www.arcella.nl/humidity-chambers where I explain how to keep wet mounts fresh and wet for many days. Essentially every mount or slide is a small culture and a lot of 'new' species come out of the debris, or cysts. It is the way I usually work, especially for observing small species.
www.arcella.nl
JH
PostPosted: Thu Nov 27, 2014 2:13 pm    Post subject: Reply with quote
Thanks Ferry
Your Website is very interesting and informative.
Regards Jörgen
Post new topic   Reply to topic    www.photomacrography.net Forum Index -> Administrator's Appreciation Gallery...Photography Through the Microscope All times are GMT - 7 Hours
Goto page 1, 2  Next
Page 1 of 2
