www.photomacrography.net :: View topic - Macro rig
Macro rig
Goto page Previous  1, 2, 3, 4
Smokedaddy
PostPosted: Fri Feb 16, 2018 11:36 pm    Post subject: Reply with quote
... no kidding, except for me "just about everything' I do in this hobby (for me anyway) is a learning curve. <g> I've 'completely abandoned my Astronomy hobby for the last 18 months and I have a TON of Astronomy projects on the back burner, including two piers that folks are waiting on. Embarassed Thankfully I didn't accept a deposit from anyone. <g>
https://secure2.pbase.com/smokedaddy/unitron_pier&page=all
-JW:
Saul
PostPosted: Fri Feb 16, 2018 11:42 pm    Post subject: Reply with quote
... let's be careful ... Smile
https://www.scrapbook.com/quotes/doc/5961.html
Smokedaddy wrote:
... https://secure2.pbase.com/smokedaddy/unitron_pier&page=all
...it is amazing...
Saul
Saul
PostPosted: Wed Feb 21, 2018 3:19 pm    Post subject: Reply with quote
Vignetting test with the 3D printed turret adapter and Componon 80mm 4.0. Passed ...
Saul
Smokedaddy
PostPosted: Wed Feb 21, 2018 3:34 pm    Post subject: Reply with quote
Sweet, very nice. So exactly what is the focus block from?
Saul
PostPosted: Wed Feb 21, 2018 3:41 pm    Post subject: Reply with quote
It was sold as a "Nikon industrial microscope focus drive"
Saul
Smokedaddy
PostPosted: Wed Feb 21, 2018 3:48 pm    Post subject: Reply with quote
... well that will be difficult to find without knowing specifics. I like the idea. I was thinking of doing something like that with a BHMJ focus block but like this much better.
PostPosted: Wed Feb 21, 2018 3:51 pm    Post subject: Reply with quote
It looks the same as the one on a Measurescope UM-2, UM-11 and some others. Labophot 1 is similar. 200µM/rev. Discussed recently regarding which side the bolts came through from!
Labophot 2 is 100µM/rev.
A BHMJ is also 200µM/rev, also about 30mm travel. Pretty much the same , though it also has a big hole through it for fitting to a pole.
PostPosted: Wed Feb 21, 2018 4:13 pm    Post subject: Reply with quote
Saul what's the black plate with the slot-head screws though it? Did you make that too?
Saul
PostPosted: Wed Feb 21, 2018 4:49 pm    Post subject: Reply with quote
ChrisR wrote:
...though it also has a big hole through it for fitting to a pole...
I have that also, just removed Smile
http://www.photomacrography.net/forum/viewtopic.php?p=227577#227577
Saul
Saul
PostPosted: Wed Feb 21, 2018 5:00 pm    Post subject: Reply with quote
You mean this one ?
I had a luck on eBay, it is from the Reichert Microsctar IV head, it was just this plate and tube lens, exactly what I needed for this adapter. As you can see from this thread, I succesfully used the same type trino head for my setup. BTW, tube lens is removed in this adapter.
If you like it, you can go different route - below you can see again bottom plate from some monocular head (suspect AO), mated with 42-72 adapter (not finished yet, have to screw it together, paint it)
Saul
Page 4 of 4
