www.photomacrography.net :: View topic - Macro rig
Macro rig
Goto page Previous  1, 2, 3, 4  Next
Saul
PostPosted: Sun Mar 19, 2017 7:41 pm    Post subject: Reply with quote
rjlittlefield wrote:
I had forgotten this thread, and I see that one of your earlier questions went unanswered.
Thanks Rik ! Looks like bottom line is - balance between vignetting and aberrations.
Saul
microman
PostPosted: Mon Mar 20, 2017 7:25 am    Post subject: Reply with quote
Interesting setups, thanks for sharing.
Saul
PostPosted: Fri Jul 28, 2017 12:50 pm    Post subject: Reply with quote
... If the distance is too short, the system may experience aberrations...
Thanks Rik, sorry for the late reply !
So, only way to check aberrations - make tests at the different distances between objective and tube lens ?
Saul
Saul
PostPosted: Wed Dec 06, 2017 6:54 pm    Post subject: Reply with quote
Small improvement to my Labophot stacking base - I got it without the light, had to use Jansjo through the back opening. Few cheap ebay parts - 10W led 272389345999 , heatsink 182195476144 & LED dimmer 282671724717 - now I have a comfort adjusting background brightness
Saul
Smokedaddy
PostPosted: Wed Dec 06, 2017 7:36 pm    Post subject: Reply with quote
Sweet setup Saul.
Saul
PostPosted: Wed Dec 06, 2017 7:48 pm    Post subject: Reply with quote
Smokedaddy wrote:
Sweet setup Saul.
Thanks James, it keeps my blood pressure lower Wink
Saul
PostPosted: Thu Dec 07, 2017 7:35 am    Post subject: Reply with quote
Are you happy with the spectrum of the LED?
Saul
PostPosted: Thu Dec 07, 2017 7:56 am    Post subject: Reply with quote
Did not try yet, fresh update . Should I look for the better CRI ? It is just for the background illumination ...
Saul
Saul
PostPosted: Thu Feb 15, 2018 3:29 pm    Post subject: Reply with quote
Got a new toy !
...and time for improvements:
Beta 3D printed dovetail adapter to the M42 extension ring
Saul
PostPosted: Thu Feb 15, 2018 3:45 pm    Post subject: Reply with quote
I was thinking of doing the same, but getting it machined. Smile
Is the thread itself 3D-printable?
Saul
PostPosted: Thu Feb 15, 2018 3:57 pm    Post subject: Reply with quote
With my colleague's 3D printer - no Smile
And even with the great printer I wouldn't do it - to press in+ glue M42 extension ring is cheaper/faster solution.
Machining - later option (if needed), after all beta testing Smile
Saul
Smokedaddy
PostPosted: Thu Feb 15, 2018 6:01 pm    Post subject: Reply with quote
... just my opinion, I wouldn't expect great results with M42x1 threads with any FDM printer. For that sort of thing you would need something like the Ember SLA/DLP resin printer (only about $8,000 plus the expensive resins). <g> Like Saul said simply gluing that puppy on is super simple.
Saul
PostPosted: Fri Feb 16, 2018 11:20 pm    Post subject: Reply with quote
OK, next step - to attach to the my existing setup
With 3D printed dovetail adapter for the tube lens/infinity objective
...and the turret version. I can use this setup with infinity objective also by placing back Reichert tube lens to the trinocular head
It is little bit overkill to have two focus assemblies in one setup....
Most probably it will be useful to use Double Flange Long High-Cycle Linear Bearing with Brake Holes instead aluminum back plate for the Optiphot focus block - something similar to https://8020.net/shop/6536.html in order to have lower profile than my previous sliding head+focus block combination.
Previous version:
BTW, my Labophot base stage does not have slide holder, so there is 3D printed solution:
Now it is much more easier to place different diffusers, screens, scrims, etc.
Saul
Smokedaddy
PostPosted: Fri Feb 16, 2018 11:24 pm    Post subject: Reply with quote
Sweet Saul.
Saul
PostPosted: Fri Feb 16, 2018 11:29 pm    Post subject: Reply with quote
Smokedaddy wrote:
Sweet Saul.
Thanks, James, it is like obsession ... not only for me, right Wink ?
Saul
Page 3 of 4
