Raynox150 vs Sigma Life-size attachment as tube lenses
liuto
Post by liuto »
I recently found a Sigma "Life-size attachment" in one of my drawers. It was originally designed for the Sigma 90mm macro lens to achieve 1:1 magnification. Since it is a 5 diopters achromatic lens I decided to test it against a Raynox 150 as a tube lens for the Nikon CFI60 4x on a Nikon D610. Initial tests were very promising but the combos turned out to be a bit weak in the corners (reversed as well as unreversed).
As Rik had just performed a very interesting test with several tube lenses I tried to present my test in a similar way for some (nonscientific) possibility of comparison. For this reason I now used the CFI60 10x lens with both tube lenses reversed. Camera again Nikon D610. The subject is from a laser printer text.
Here a few 100% crops, unsharpened but with levels correced.
center:
corner:
Although the Sigma (S) is only a two element lens it seems to perform very nicely against the three element Raynox (R).
Right after this test I was interested how the Raynox 250 performed in the corners on a full format camera. I did no stack but in magnified live view mode they looked quite good too.
Best regards
Hermann
Very nice. Interesting that you got less longitudinal CA (blue haze) with the Nikon+Sigma than with the Nikon+Raynox.
bugbear
Post by bugbear »
This Sigma adapter starts to look like an interesting beast, given my (different context) results;
I foresee a price rise for them on eBay...
BugBear
