www.photomacrography.net :: View topic - Büchse der Pandora in Aluminium
Post new topic   Reply to topic    www.photomacrography.net Forum Index -> Administrator's Appreciation Gallery...Macro and Close-up Images
Guppy
PostPosted: Fri Feb 14, 2014 2:45 pm    Post subject: Büchse der Pandora in Aluminium Reply with quote
This time is Pandora's Box a Aluminium Tube.
I use the NIKON M Plan, 60/0.7 LWD, 210/0, with 60:1, Sharpness depth 1.1µm.
The picture width amounts 0.39mm.
These were 427 pictures, stack with Zerene.
The steps are 0.25 µm.
Kurt
www.focus-stacking.ch
PostPosted: Fri Feb 14, 2014 4:41 pm    Post subject: Re: Büchse der Pandora in Aluminium Reply with quote
This is beautiful!
Guppy wrote:
I use the NIKON M Plan, 60/0.7 LWD, 210/0, with 60:1, Sharpness depth 0.6µm.
To clarify... It looks like you're using a "sharpness depth" that is measured as maximum deviation from the point of sharpest focus. The total DOF is twice as much. The formula for total DOF is lambda/NA^2, which for green light at lambda=550nm would be 1.12 µm. Because this subject has a lot of blue in it, we might use lambda=450nm to give a tighter estimate of 0.92 µm.
In either case, your steps of 0.25 µm are certainly small enough to avoid focus banding.
dolmadis
PostPosted: Sat Feb 15, 2014 1:45 am    Post subject: Reply with quote
Hi Kurt
Can you share the details of the tube you used please?
Thanks
John
Guppy
PostPosted: Sat Feb 15, 2014 4:31 am    Post subject: Reply with quote
Hi John
looking at the following address:
http://www.photomacrography.net/forum/viewtopic.php?t=22725
This Time the tube is in aluminum and not in PVC, without a second tube.
Kurt
dolmadis
PostPosted: Sat Feb 15, 2014 5:03 am    Post subject: Reply with quote
Thank you, Kurt.
John
baro-nite
PostPosted: Sat Feb 15, 2014 12:08 pm    Post subject: Reply with quote
Extraordinarily beautiful work, and an inventive and elegant technique.
Jeff S
abpho
PostPosted: Sun Feb 16, 2014 8:15 pm    Post subject: Reply with quote
Beautiful image.
PostPosted: Mon Feb 17, 2014 7:42 am    Post subject: Reply with quote
Beautiful picture!
abpho
PostPosted: Sat Mar 01, 2014 4:35 pm    Post subject: Reply with quote
Congrats Kurt.
jazzper
PostPosted: Mon Mar 03, 2014 8:00 am    Post subject: Reply with quote
This is an absolutely brilliant idea! And the result is beautiful as well - great work!
Jesper - Flickr
Yousef Alhabshi
PostPosted: Mon Mar 10, 2014 4:15 am    Post subject: Reply with quote
Superb.. amazing sharpness at this level of magnification.
Congrats
http://www.flickr.com/photos/alhabshi/
Post new topic   Reply to topic    www.photomacrography.net Forum Index -> Administrator's Appreciation Gallery...Macro and Close-up Images All times are GMT - 7 Hours
