www.photomacrography.net :: View topic - Psychedelic new forms added
Goto page 1, 2  Next
Post new topic   Reply to topic    www.photomacrography.net Forum Index -> Administrator's Appreciation Gallery...Photography Through the Microscope
Linden.g
PostPosted: Sun Dec 08, 2013 7:32 am    Post subject: Psychedelic new forms added Reply with quote
I thought I'd take advantage of the 90 degree lighting capability of the BH2-UMA and explore the interference patterns from oil on water. Its very trippy. Taken with Neo Splan 5x and LED lighting in place of the halogen unit.
Linden Gledhill http://www.flickr.com/photos/13084997@N03/
JH
PostPosted: Sun Dec 08, 2013 10:47 am    Post subject: Reply with quote
Made my day!
Regards J├Ârgen
PostPosted: Sun Dec 08, 2013 12:05 pm    Post subject: Reply with quote
That enormous beauty!!!
PostPosted: Sun Dec 08, 2013 12:10 pm    Post subject: Reply with quote
Beautiful wow Wink
www.microscopeitaly.it
Litonotus
PostPosted: Sun Dec 08, 2013 12:27 pm    Post subject: Reply with quote
great!
my FB page
Stefano B
PostPosted: Sun Dec 08, 2013 1:50 pm    Post subject: Reply with quote
beaufiful shots! Very Happy
Linden.g
PostPosted: Sun Dec 08, 2013 5:21 pm    Post subject: Psychedelic new forms added Reply with quote
Thanks for the kind comments. The variation of structure is almost endless.
Bruce Taylor
PostPosted: Sun Dec 08, 2013 7:28 pm    Post subject: Reply with quote
Those are incredible! Very Happy
It Came from the Pond (Blog): http://www.itcamefromthepond.com/
harisA
PostPosted: Mon Dec 09, 2013 2:01 am    Post subject: Reply with quote
Impressive images.
Are this taken with epi illumination?
What exactly we see in the images? a mixture of oil and water or something else..
Marek Mis
PostPosted: Mon Dec 09, 2013 4:36 am    Post subject: Reply with quote
Beautiful and ineteresting images !
Marek
Linden.g
PostPosted: Mon Dec 09, 2013 6:12 am    Post subject: Reply with quote
harisA wrote:
Impressive images.
I'm using a BH2-UMA the set-up is here http://www.photomacrography.net/forum/viewtopic.php?t=22147
The shapes are due to a very thin layer of hydrophobic liquid residue left behind from evaporated gasoline on the surface of water. The colors are due to the interference caused by white light bouncing off the top and bottom boundary interfaces. Oil/air and oil/water. As the more volatile solvents evaporate the oil layer gets thinner and this shifts the colors seen. Surface tension, curved edges and particles all impact the thickness of different parts of the floating droplets which all adds to the complexity. This is a similar effect as seen in soap films.
harisA
PostPosted: Mon Dec 09, 2013 6:34 am    Post subject: Reply with quote
Linden.g wrote:
harisA wrote:
Impressive images.
The shapes are due to a very thin layer of hydrophilic liquid residue left behind from evaporated gasoline on the surface of water. The colors are due to the interference caused by white light bouncing off the top and bottom boundary interfaces. Oil/air and oil/water. As the more volatile solvents evaporate the oil layer gets thinner and this shifts the colors seen. Surface tension, curved edges and particles all impact the thickness of different parts of the floating droplets which all adds to the complexity. This is a similar effect as seen in soap films.
Thank you Linden althought there is one final issue puzzling me.These colour effects are due to light from above (epi illumination)or you illuminate your specimen with the aid of an external light source(as seen in your setup photo)
PostPosted: Mon Dec 09, 2013 8:11 am    Post subject: Reply with quote
wow, super !
Linden.g
PostPosted: Mon Dec 09, 2013 10:32 am    Post subject: Reply with quote
Sorry for the confusion, I'm using the side lighting only when I need to balance the flat epi light but in the case of the oil it's not used. I'm using the direct epi (bright field) without the analyses polarizer.
Linden
harisA
PostPosted: Mon Dec 09, 2013 1:33 pm    Post subject: Reply with quote
Thank you Linden.
Post new topic   Reply to topic    www.photomacrography.net Forum Index -> Administrator's Appreciation Gallery...Photography Through the Microscope All times are GMT - 7 Hours
Goto page 1, 2  Next
Page 1 of 2
