www.photomacrography.net :: View topic - X, Y and Z automation on BH2-UMA set-up
Linden.g
PostPosted: Mon Dec 02, 2013 4:46 pm    Post subject: X, Y and Z automation on BH2-UMA set-up Reply with quote
I spent a few days automating an Olympus metrology BHM system with three StackShot drives. One used as a direct drive on the focus control and then two full StackShots rails at 90 degrees to each other driving a post going through an extended sample stage on a standard X-Y table. The post has a sleeve bearing to allow focusing. Two prototype StackShot controllers are connected together and talk to each other allowing fully automated X-Y panning. Unfortunately at the moment I cannot connect three controller together so the stacking has to be set off manually. Cognisys will have a three axis controller sometime next year. The system works surprisingly well considering its hacked together. I did a couple of test stacks of wing scales. I've also done a pan of a coin but haven't combined stacking with panning because a need a new computer Very Happy
Linden Gledhill http://www.flickr.com/photos/13084997@N03/
JH
PostPosted: Fri Dec 06, 2013 10:51 am    Post subject: Re: X, Y and Z automation on BH2-UMA set-up Reply with quote
This is wery interesting, thanks for sharing.
Do you have any more information about the three axis controller?
Regards J├Ârgen
pierre
PostPosted: Sat Dec 07, 2013 9:26 am    Post subject: Reply with quote
Quite impressive
Shocked
Regards
Pierre
Linden.g
PostPosted: Sun Dec 08, 2013 4:54 pm    Post subject: Reply with quote
Thanks Pierre
Jorgen, I've seen the prototypes and don't know a lot of details but it will be a single control unit which can control at least three motors. Should be very impressive for X Y and Z motion and any other motion control application.
Linden
