www.photomacrography.net :: View topic - arcyria denudata and physarum leucophaeum [?] slime moulds
Post new topic   Reply to topic    www.photomacrography.net Forum Index -> Administrator's Appreciation Gallery...Macro and Close-up Images
Greenfields
PostPosted: Wed Oct 23, 2013 11:43 am    Post subject: arcyria denudata and physarum leucophaeum [?] slime moulds Reply with quote
All images are stacks. Zerene Stacker PMax. 5D3 Canon MP-E 65mm. Magnification 4x [slices at 33 micron intervals] or 5x [slices at 25 micron intervals]. Lighting: Canon MT-24EX. 1/8 to 1/18 power. Diffuser = tube of 80 gsm printing paper round barrel
Arcyria denudata fruitbodies
Tricky subject: The mass of filaments tends to move between slices, presumably twisting in response to heat and/or humidity to discharge the spores.
Physarum leucophaeum
Not completely confident about the identification because the species varies and others resemble it. In the final image the metallic lustre may be due to thin-film interference effects on parts of the membrane of the sporangium not covered by the mineral granules.
Henry
Feel free to edit my images.
PostPosted: Sun Nov 17, 2013 8:01 am    Post subject: Reply with quote
I'd missed these! Thanks for showing us beautiful shots of these bewildering Anxious organisms.
That's the best adjective I can find for them!
Where did you find them?
Greenfields
PostPosted: Wed Nov 20, 2013 1:40 pm    Post subject: Reply with quote
Chris, Thank you for the comments.
Both examples came from wet but drying logs at Ebernoe Common, West Sussex.
These fruitbodies are, typically, about 0.8mm in diameter so they are very inconspicuous unless you are crawling about in the leaf-litter when working on something bigger and happen to see a group of them.
As you will know, but just in case others are interested they are strange life forms. At one time they were considered to be a variety of fungus but now they are seem as something on their own. For much of their lifecycle they are practically invisible, single-celled algae feeding off bacteria and organic debris. In the right conditions, some species [including these] aggregate and merge together forming a plasmodium which contains a very large number [millions] of nuclei sharing a common plasma. The plasmodium can move about and continue to feed. In the right conditions [I assume of temperature, humidity and when the local food supply is exhausted] the plasmodium forms fruitbodies. Some species form a small number of large fruitbodies. others larger number of small ones each containing millions of spores which is what you see in these pictures.
Henry.
micro_pix
PostPosted: Fri Nov 22, 2013 2:40 pm    Post subject: Reply with quote
I'm not an expert but I think that the fourth and fifth of your outstanding photos are actually Physarum album. This is due to the way that the capillitium radiates from the sporocarp base, the shape of the lime bodies and the flattened shape of the sporocarps. There is a good Key at Danish Myxomycetes
Both sets of images are superb but your A. denudata photos are the best I've seen.
Dave
Greenfields
PostPosted: Tue Nov 26, 2013 11:26 am    Post subject: Reply with quote
Thanks, Dave.
Your identification does make sense. I am very much a novice in this field.
Henry.
PostPosted: Sun Dec 29, 2013 7:29 pm    Post subject: Reply with quote
Outstanding photographs . I cannot set foot outside after a warm summers rain without looking for these things. Mostly here its is Metatrichia vesparium that I find along with Fuligo septica and a few Badhamia species. Very Happy
Post new topic   Reply to topic    www.photomacrography.net Forum Index -> Administrator's Appreciation Gallery...Macro and Close-up Images All times are GMT - 7 Hours
