www.photomacrography.net :: View topic - Ectemnius / Part II
Ectemnius / Part II
Post new topic   Reply to topic    www.photomacrography.net Forum Index -> Administrator's Appreciation Gallery...Macro and Close-up Images
babilon76
PostPosted: Tue May 21, 2013 1:13 am    Post subject: Ectemnius / Part II Reply with quote
Ectemnius sp.
116 shots
Nex-5n with JML 21mm
Magnification around 3.5x-4x
http://www.flickr.com/photos/harisprin/8716719143/
canonian
PostPosted: Tue May 21, 2013 2:44 am    Post subject: Reply with quote
Gorgeous on all levels.
Nice background, clean specimen, good lighting, low noise.
Seen the full size at Flickr, like this composition more than Part I.
I'm always interested to see how the NEX performs in macrophotography, what you showed is very promising.
How did you mount the JML, what is used to go from NEX to JML? ( adapters/bellows ?)
A photo of your setup would be greatly appreciated.
Fred
Canonian@Flickr
babilon76
PostPosted: Tue May 21, 2013 4:01 am    Post subject: Reply with quote
Hi Fread
Thank you very much for your kind words.
I used a Nikon to Nex adapter,bellows, a 52mm reverse adapter to Nikon and a 30,5mm to 52mm step up ring in order to connect Nex with JML. Also I used a couple O rings and some teflon tape in order to seal the JML from the light.
My new setup is under construction.When I finish (hope soon) I'll upload some photos.
PostPosted: Tue May 21, 2013 6:31 am    Post subject: Reply with quote
Excellent indeed!
This one really shows what's possible with this little $9 JML lens.
--Betty
Atticus Finch: "You never really understand a person until you consider things from his point of view
- until you climb into his skin and walk around in it."
Lee, N. H. 1960. To Kill a Mockingbird. J. B. Lippincott, New York.
Rylee Isitt
PostPosted: Tue May 21, 2013 8:04 pm    Post subject: Reply with quote
babilon76,
Excellent image! Everything about it is exceptional. I'm a big fan of nice, soft backgrounds with gentle color transitions too, so ya got me there too!
Planapo,
Oh, I only wish it were still $9 Wink
ckatosmith
PostPosted: Wed May 22, 2013 6:02 pm    Post subject: Reply with quote
Very immaculate and pleasing, thank you for posting it.
Can you say what distance apart the shots are? Thank you,
Carolina
babilon76
PostPosted: Thu May 30, 2013 12:39 pm    Post subject: Reply with quote
Betty,Rylee,Carolina thank you very much for your kind words.
Carolina unfortunately I can't remember the distant between the shots.
Haris
peterkinchington
PostPosted: Fri Jun 07, 2013 4:38 pm    Post subject: Ectemnius wasp image Reply with quote
Haris,
Superb Image!
Cheers Peter Kinchington
Try, try again. Fall down nine times get up ten.
www.peterkinchington.com
martincito
PostPosted: Mon Jun 10, 2013 10:28 am    Post subject: Reply with quote
A breath-taking image. Thanks for sharing it... it's inspirational!
Martin
abpho
PostPosted: Tue Jun 11, 2013 6:14 pm    Post subject: Reply with quote
I'm jealous. This is an amazing shot.
martincito
PostPosted: Wed Jun 12, 2013 1:26 am    Post subject: Reply with quote
It's immaculate! How did you get that wasp so clean?
babilon76
PostPosted: Sun Jun 16, 2013 2:13 am    Post subject: Reply with quote
Peter,Martin,abpho thank you very much for your comments
Martin First I wash the insect with distilled water after that I wash it again with a solution made by distilled water,few drops alcohol and 30% aceton and finaly I dry it gently with the blower.
PostPosted: Wed Jun 26, 2013 8:06 pm    Post subject: Reply with quote
Brilliant! Deserves to be on the front page. Well done.
Koorosh
PostPosted: Tue Dec 30, 2014 3:28 pm    Post subject: Reply with quote
So impressed with what that camera has picked up! I took some images of Ectemnius and was never satisfied with the outcomes. Cracker of a shot that one.
What sort of lighting did you use? And how does using a Sony for macro work, work out? I'm looking to buy an a6000 this February and just really wonder how it is I'll be using it essentially.
yaya21
PostPosted: Wed Dec 31, 2014 2:12 am    Post subject: Reply with quote
wonderful!!!
Post new topic   Reply to topic    www.photomacrography.net Forum Index -> Administrator's Appreciation Gallery...Macro and Close-up Images All times are GMT - 7 Hours
