Been a long time since i've been on. I see I've been missing out on a lot!
I was given a Leitz LL 20X and I was looking into adapters to go from the RMS mount to t-mount (is this right?) and using a t-mount fine focus adapter (http://www.edmundoptics.com/optomechani ... ube/52-300) and t-mount to EOS adapter. I am using a Canon 5D Mark II
I started wondering if there is a way to find out the proper distance the microscope objective is supposed to be away from the film/sensor plane to minimize distortion, aberrations while maximizing sensor area coverage. I understand the distance from the the sensor will directly affect the working distance to the subject and am only worried if it causes the front objective to contact subject.
With 25mm of extension from the mount on the camera with a homemade mount i was able to focus about 5cm away but saw a lot of pincushion distortion and chromatic aberrations in the the corners. I believe a lot of it was due to the sloppiness of the construction and being hand held.
I have not ordered any of the adapters or the focusing tube yet. This will be my first microscope objective so I'm very excited but want to do it right. Any advice is appreciated.
Proper Objective to film plane distance
- Charles Krebs
Be sure to read our FAQ: How can I hook a microscope objective to my camera?
From the numbers listed in your posting, I strongly suspect you haven't done that yet.
Re: Proper Objective to film plane distance
Leitz objectives aren't adequate to work as macro lenses (direct projection on sensor) because they need complementary aberrations correction done by a Leitz Periplan compensating eyepiece. And they likely will not cover full frame sensor: usually thery are designed for 20mm image circle eyepieces or in the best case (Pl designed for Orthoplan) 28mm image circle.McMacroBigMac wrote:I was given a Leitz LL 20X and I was looking into adapters to go from the RMS mount to t-mount ....
... and t-mount to EOS adapter. I am using a Canon 5D Mark II
In the best case you will get a good image centre with nasty periphery.
Another important point is the "coverglass" correction: if it is intended for inverted microscopes (170/1 or similar) they are designed to see through a 1mm thick glass and will be afected by heavy spherical aberration. If designed for 0.17 coverglas this will be not as important if the NA is up 0.30, if it's a metallurgical objective (210/0 or 170/0) this isn't an issue because they are designed to work without coverglass.
And of course if it is infinite corrected as Charles sugests you need a "tube lens", but the former caveats still apply.
Please post the complete specification if you want further clarifications.
Pau,
The markings are
LL 20X / 0.40
∞/0/30
If it requires additional lenses and accessories I might see about getting a different one. I helped a guy out and he gave it to me, he has others he said. anything you recommend? I'm gonna read thru the equipment section too. I have a canon 65mm 2.8 mp-e and am looking for something maybe a little higher magnification.
Thanks for all the info,
-Keegan[/b]
The markings are
LL 20X / 0.40
∞/0/30
-Keegan[/b]
It's a metallographic objectiveMcMacroBigMac wrote: The markings are
LL 20X / 0.40
∞/0/30
LL means long (or very long) working distance, a desirable feature for macro
∞/0 infinite corrected an no cover glass. It needs an adequate tube lens (I don't kow its focal lengh) and no glass covered specimen
/30 I dont know. If it means the working distance it will be a very long one for a microscope objective (again good)
But as I said it do need a tube lens and a compensating eyepiece (ie to be used in the adequate microscope) so it will be problematic for direct projection. Because you already own it you can test it, but I wouldn't expect good performace.
Few objectives are adequate for direct projection on full frame. Other members would give you better advice. For APSC many Nikon CF finite series are very good, but I don't know for FF.
