Charaxes candiope, wing scales II
A few more from this butterfly. In the upper left of the first image, and in the second image, the scales on the side photographed become a little scattered and spread out. You can see they are attached to a greenish-yellow wing membrane that is transparent. Through this membrane you can see smaller, different shaped scales that are attached to the other side of the wing. Those scales were much more translucent and reflective and changed appearance significantly just by catching the light at different angles. I may need to try another shot with a touch of backlighting to show just how interesting these sections can appear.
Nikon MM-11. Olympus UMPLFL 5/0.15. Canon T3i. Stack of 14 images. 5X on sensor.
Nikon MM-11. Olympus UMPLFLN 10/0.30. Canon T3i. Stack of 34 images. 10X on sensor.
Nikon MM-11. Olympus UMPLFLN 10/0.30. Canon T3i. Stack of 26 images. 10X on sensor.
naturephoto1
Post by naturephoto1 »
Superb set of images.
Rich
Again excellent images, Charles.
Amazing!
carlos
flyer2o12
Post by flyer2o12 »
Absolutely beautiful images Charles. 8)
Craig Gerard
Post by Craig Gerard »
...snip...Those scales were much more translucent and reflective and changed appearance significantly just by catching the light at different angles. I may need to try another shot with a touch of backlighting to show just how interesting these sections can appear.
I look forward to seeing the results.
pierre
Post by pierre »
Impressive !
Regards
Pierre
Ecooper
Post by Ecooper »
These photos are absolutely stunning!
EC
Thanks all for the kind remarks!
I have a Charaxes candiope in my collection... Beautiful butterfly and beautiful photos.
