Underwater cups -- a puzzle piece
A puzzle piece... Anyone want to guess what these are?
Stereo, cross eye. Frame width about 8.9 mm, shot as two stacks through about 1/4" of water.
Looks like the sort of thing you'd find at the bottom of a thermal spring. A concretion of salt deposits and heat tolerant bacteria.
It does, doesn't it?
But I've been assured that no bacteria were involved in the growth of these structures. I think they don't have any significant salt deposits either, though that's a bit less clear to me.
pierre
Post by pierre »
Hi Rik,
Is it a kind of emulsion covered by a glass ?
Regards
Pierre
Harold Gough
Post by Harold Gough »
I would suggest algae as prime suspect.
Hariold
Pierre, thanks for taking a shot.
These structures did form in contact with a liquid emulsion, but I'm unclear whether the solid forms shown here are emulsions also. Definitely no glass was involved.
The cup-like structures were originally covered by an opaque liquid. I first observed them when the liquid was drained. Then I rinsed them a couple of times with clear water and left them covered with a thin layer of water to eliminate distracting reflections during photography.
Harold, definitely not algae, but I agree that the appearance would suggest that.
pierre
Post by pierre »
Hi Rik,
Thanks for your comments and clarification.
Regards
Pierre
To provide some more clues, I'll add that despite their dubious appearance these growths are commonly found in even the best kept households and present no health hazards whatsoever. :)
Harold Gough
Sliced bread?
Harold
Post by Wim van Egmond »
a sponge?
Nice 3D!
Wim
descall
Post by descall »
Lime scale in the kettle?
Thanks for dropping in, folks.
No bread or sponges involved here, except in the environment surrounding the subject. Not much lime scale either but that's definitely working in the right direction.
I'll add that the cups formed quickly, a few minutes at most.
Here is another view of the same structures, this time with a wider field and looking straight down.
The cups were a "found" subject that I just happened to notice. I was intrigued by the 3D structure (thanks, Wim!) so I took some time to photograph them.
This morning I specifically tried to reproduce the cups using a simplified setup. The attempt was promising, but not entirely successful:
I hope this helps!
Peter M. Macdonald
Post by Peter M. Macdonald »
Something with a film of grease which has been left soaking in detergant?
Nope, no grease, no detergent. The cups were highly resistant to both water and grease-cutting solvents. They were not very strong, however: easily removed by rubbing with a plastic mesh pad.
Craig Gerard
Post by Craig Gerard »
Rik,
Do you eat oatmeal for breakfast and sometimes forget to turn the hotplate off in time?
