Yes, BUT that's only with the 4X objective that you asked about.WebbCMH wrote:So can I infer from the above that if focus stacking I would have around 6-8mm of attainable depth of field in focus?rjlittlefield wrote:With my Canon 100mm f/2.8L IS USM lens, focus range is about 3 mm with the lens from infinity to 1 meter, and another 3 mm from 1 meter to 0.5 meter. You can probably push that farther and still retain good image quality.WebbCMH wrote:1) Assuming the camera and lens were to remain still and using helicon remote to step the focus what kind of focus range would a 105mm micro nikkor VR with the 4x Nikon Objective achieve.
When you scale up to the 10X objective, the depth of field achievable by internal focusing gets a lot smaller.
I tested just now with my Nikon MRL00102 objective on the Canon 100. Focus range from infinity focus to 1 meter is only 0.53 mm. I can get another 0.86 meter by refocusing from 1 meter to 0.5 meter, but the corners go astigmatic. At 1:1 focus on the tube lens, the total range from infinity is over 3 mm, but by then even the center is trash.
I recommend not using internal focusing with a 10X objective for subject depth beyond about 0.5 mm.
That's not enough for butterfly wings that have the most interesting colors and textures.
You need to get yourself a StackShot or some other high precision linear focusing device.
