www.photomacrography.net :: View topic - Sidewalk Weevil
Sidewalk Weevil
BugEZ
PostPosted: Sat Mar 24, 2012 5:54 am    Post subject: Sidewalk Weevil Reply with quote
Here are three images of a small weevil found on the sidewalk. We have had an early spring and this one was discovered about a month earlier than in prevous years.
I post primarily to illustrate the results I am getting with my new JML 20X lens.
Overall shot
~2X using El Nikkor 50mm enlarging lens reversed. 29 images, Pmax
~10X synthetic stereo pair
This uses my 10X OLY infinite with a 200mm telephoto as a tube lens. Approximately 70 images, stacked with Zarene, Pmax.
Finally an image with my 20X JML
The JML is mounted to my 200mm Tele. 125 images stacked with Zarene, Pmax, no cropping.
Keith
PostPosted: Sat Mar 24, 2012 10:42 pm    Post subject: Reply with quote
Looks great -- I really like the way that knee joint looks in the stereo. I can't remember -- was this your first go with Zerene's synthetic stereo?
BugEZ
PostPosted: Sun Mar 25, 2012 9:20 am    Post subject: Reply with quote
Rik wrote:
Quote:
First go with Zerene's synthetic stereo?
Yes and no. I had tinkered with it several months ago, but was distracted by other things and didn't actually complete the images.
I enjoy stereo images posted by others. In particular your excellent fly mouth part series. I was taking many "true" stereos with mixed results so I decided to give Zarene's synthetics another try. I have made some other synthetic stereo images. I posted the "knees and snout" since that helped provide background for the image of the weevil’s antenna taken using the JML objective.
This feature of Zarene works very nicely and I think I have gotten the hang of it now. I especially like that the second image processes more quickly than the first, so the software “magic” is smart enough to take advantage of what it learned the first time through. Much appreciated!
Keith
PostPosted: Sun Mar 25, 2012 9:45 am    Post subject: Reply with quote
The result here is excellent. If you can repeat that easily, then you've definitely arrived.
Second and subsequent passes are faster because they reuse the basic alignment information that was determined on the first pass. No alignment required.
Another trick for speeding up stereo is to take advantage of the fact that stereos are usually reproduced smaller than single images. This allows to do stereos with Options > Preferences > Preprocessing set to Pre-size smaller and skip frames. I usually run stereos at 50% and every 2nd frame, which makes stacking go about 5X faster. Selecting the Pre-size option will redo the alignment, so it's best to do this in a separate project especially if you anticipate doing any retouching on the full-size results.
