Chris S. wrote:
FYI, the flash durations on my old Nikon SB-26 speedlights range from 1/1000 second at full power to 1/23,000 second at 1/64 power.
If the flash duration is 1/23,000 sec then the mean displacement would be very low, definitely lower than with a 2 sec exposure per my equations. The cross-over point where a 2 sec exposure is equal to a first curtain flash is if the flash duration is about 1/8000 sec.
Chris S. asked:
I’m curious as to how, in your laser tests, you measured displacement so finely. And to be clear, do your numbers describe displacement of the reflective foil, or of the projected laser beam?
Hmmm... I am starting to get a bit nervous here. I feel a bit like the wizard in the
Wizard of Oz movie and you are peeking behind the curtain... The distances I estimated (.001 in for the shutter bounce and .003 for the mirror bounce) are based on the shift of the reflected pattern on the wall. I did not accurately measure this with a ruler but approximated. The wall where the pattern was projected was approximately 10x farther from the rig than the laser so I divided the patch motion by 10 then picked the "Disp0" term in the equation to be half of that since I observed a "total amplitude" and the Disp0 them is a "half amplitude".
The absolute magnitude does not matter as much as the relative magnitude, and I definitely got the proportions right.
Chris S. also asked :
Also, do I understand correctly that your settling times are calculated, as opposed to measured? How did you determine values for f and k?
Hmmm... more behind the curtain stuff... The k term is the decay constant and was chosen so that the observed decay approximately matched the output of equation. Things were definitely steady after about a half to a quarter of a second, even with the large mirror snap, so I picked a k term that matches that. I would add that this is a rather subjective observation. The f (frequency) term is also a bit subjective. The rig (or any structure for that matter) will have many vibration modes and the damped decay of each mode will vary a bit. It appeared to me that the motion in the oscillatory "blur" of the patch as it settled was nearly discernable, but not quite. I take that to be something a bit faster than 15 Hz so I chose 20. Again a more subjective choice than a measured value.
Hope this helps.
These are good questions. My posting appears a bit more "studied" thatn it actually is. If I can locate an inexpensive phonograph cartridge, I will fashion a crude accelerometer and make some proper measurements of settling time and vibration frequency and relative amplitude on my rig. Perhaps
Charles Krebbs comment about vibrations:
...it seems to me that the key thing is to be aware they exist and tackle them appropriately for your set-up.
is most appropriate.
I have figured out my "gate" scheme to allow me to switch on the bucket light and made a schematic. I have to buy a switch to allow me to choose between an "automatic" and "manual" mode on the power regulator, but the rest of the parts are in-hand. I should have it wired up in a few days.
Kind regards,
Keith
