The photography through the pzo scope (with dic) seems to be improving. It does need a lot of light. The best of this night's session - some sort of vorticella or similar I presume. Some way to go - but I'm happy for now. Joris
PZO Biolar, PZO DIC set, Nikon E Plan 20x, Flash
The PZO DIC seems to be working ...
Yes - it must be much sharper. It looks a lot better in real life and to my eyes different from oblique (as I get it with the decentering/mismatching the phase condenser on the BH2); I'm seeing a lot of detail I hadn't seen before with any of the lighting techniques on my BH2.
It seems the way I photographing now however loses a lot of sharpness (much more then on the olympus) - I'll need to check why - maybe the photography adapter and the PZO head do not match very well. I'm waiting delivery of a trino head and projecting eyepiece and will see if this improves.
Probably I could have experimented more with oblique before buying a DIC set - but then, I am not like that ...
Joris
Joris
Ah - I read the discussion on the "voila" technique (http://www.photomacrography.net/forum/v ... php?t=4386). This is with both prisms in and I can vary the background color/density by moving the upper prism - but I guess I shouldn't be seeing one-sided shadows with "true" DIC - as I have above ? I'll check allignment of everything; also my flash technique isn't to great here: just holding a small flash under the condensor. Can this have an effect on the resolution ? Joris
This seems to be somewhat better: an Arcella with some internals (nuclei ?) visible - not yet the quality i'm seeing in the main gallery, but improving ! I'm seeing a lot of dust everywhere on the surface in the scope and on the prisms, so that will be my next improvement effort. Joris
PZO scope+DIC set+Olympus Splan40
