| Author |
Message |
MacroB
Posted: Tue Dec 27, 2011 9:24 am Post subject: Help wanted breaking thro the High Magnification Barrier |
Happy New Year to All!
Thought that the Before & After Focusing might help but it only increased the quantity of slices and made the foreground confusing.
Maxillary Palp 30X at 793 slices and 0.001 mm with alignment turned off.
Have tried less slices and thicker but it did not help.
Camera Canon 50D with Leica X16 lens system, Einstein 640, MT-24EX, poly cup diffuser and Cognisys rail and control box.
Would slabs help?? Have looked at ZS's Batch Dialogue> Current Batch & Stacking tasks but it did not mean much.
When I went to school Technology was having electricity at home. Would be grateful if someone could point me in the right dirrection.
Best Wishes,
Bob
[img][/img]
| Back to top |
rjlittlefield Site Admin
Joined: 01 Aug 2006 Posts: 12560 Location: Richland, Washington State, USA
Posted: Tue Dec 27, 2011 10:51 am Post subject: |
Bob,
To upload photos:
1. Make sure that they are no bigger than 1024x1024 pixels (resize as needed).
2. Save as JPEG with a "quality" setting that makes the file length be about 200-250 kilobytes (KB).
3. Follow carefully the directions at http://www.photomacrography.net/forum/viewtopic.php?t=7, especially the ones at Step 5 that say where you have to click to get a link inserted.
I'm looking forward to seeing the image...
--Rik |
| Back to top |
Craig Gerard
Posted: Tue Dec 27, 2011 2:19 pm Post subject: |
Bob,
A recent discussion may provide the information you seek:
| rjlittlefield wrote: | A workflow that is tedious but simple to understand goes like this:
Launch ZS
Load all source images
Stack > Align All Frames
Select images 1-20
Stack Selected (PMax)
Select images 11-30
repeat previous two steps for all other slabs.
Select all output images
File > Save Output Image(s) to some scratch directory.
Exit ZS
Re-launch ZS
Load the images you just saved
Uncheck everything at Options > Preferences > Alignment
Stack > Align & Stack All (DMap). |
Reference:http://www.photomacrography.net/forum/viewtopic.php?t=15075
Craig _________________ To use a classic quote from 'Antz' - "I almost know exactly what I'm doing!" |
| Back to top |
Posted: Tue Dec 27, 2011 2:55 pm Post subject: |
Bob,
I think you're on the right track to try slabs. Your current image appears to have been processed entirely with DMap. That seldom works very well at high magnification, especially with a subject that has as much overlapping structure as this one does. No matter what method you use, you're going to end up with "transparent foreground" artifacts that have to be fixed with manual retouching. Both of those problems will be reduced by processing in slabs using PMax, then combining the results with DMap.
There will also be loss of contrast in some background regions, due to their being partially hidden from the lens behind foreground structures. There's no cure for that. It's an optical effect that's present in the original images.
In the image that's shown, I'm struck that nothing seems very sharp. Since you're shooting with flash, I think we can rule out vibration as a cause. So I'm left wondering about the optics.
What exactly is a "Leica X16 lens system"? Does it have an adjustable aperture, and if so, what do you have the aperture set to?
--Rik |
| Back to top |
MacroB
Posted: Wed Dec 28, 2011 3:06 am Post subject: |
Hello Rik,
The X-16 lens system is a Leica planapochromatic zoom macroscope which I have mounted horizontally on an optical bench.
This is a PMAX image with the diaphragm set to 4, where 1 is the smallest and 5 the biggest. Probably no comparison to camera f numbers! Just occured to me does a microscope somehow work in reverse to camera regards size of aperture. Should I be using 1?
When I uploaded the jpeg it went darker than original, just checked the memory stick on main computer. Also had a look at first few images of this stack - No 1 the leading setae are OOF with No 2 probably the sharpest of all, though NOT pin sharp when viewed on large monitor.
Certainly when I was focusing and viewing on camera LCD all seemed sharp, however, I thought the disappointing sharpness poss. due to large 27" IIyama screen.
Bob |
| Back to top |
Joined: 14 Mar 2009 Posts: 3035 Location: Near London, UK
Posted: Wed Dec 28, 2011 6:57 am Post subject: |
HI Bob - well, no answers so I with little knowledge, will chime in..
you almost certainly want the LARGEST HOLE at this magnification, and I think that's going to be at the "1" end!
No way to eyeball the lens??
Edit a couple of hours later:
I've just been reading of Zeiss macro lenses where an East German one used the lower mumbers for smaller apertures, but West German were the other way around.  |
| Back to top |
MacroB
Posted: Wed Dec 28, 2011 9:34 am Post subject: |
Hello Craig, thanks for the workflow for forming the slabs. I'm sure at some stage that will come in useful - though at the moment like the photo, it's all a blurr.
Hello ChrisR, Yes, I did manage to get the front lens off and check on the aperture. It was as I had always thought - the opposite to a camera lens, with 5 being the biggest.
It was worth a try, sometimes it's just a chance remark that solves the problem.
Have been looking at my software settings to see if the answer might be there. Am using Digital Photo Pro and EOS Utility.
Thanks again,
Bob |
| Back to top |
Posted: Wed Dec 28, 2011 9:44 am Post subject: |
| Do try it at 5 then, diffraction KILLS! |
| Back to top |
Posted: Wed Dec 28, 2011 10:38 am Post subject: |
Bob, I may have misunderstood your words, but I'm cringing a bit at the thought of disassembling a planapochromatic lens. Part of their good correction comes from very fine control of spacing and centering between elements. If anything goes the slightest awry on reassembly, the lens won't work as well as it did when it left the factory.
Next time you need to check which way an aperture goes, just remove the camera body and look through the lens the same way the camera would. That will give you the same information about the aperture, plus let you inspect for stray reflections, all at no risk to the optics.
Now, back to your problem...
I'd like to see a couple more images:
1. Overview snapshot of your whole setup.
2. Actual-pixels crop of the sharpest portion of one source image.
Regarding the aperture, I always suggest to shoot a series of individual frames, stepping aperture from smallest to widest. Look closely at what you get, and choose whatever aperture turns out to be the sharpest. It will probably be at or near wide open, but the exercise will confirm that and will also give you some feel for what diffraction does with smaller apertures.
Once you know the sharpest aperture, then you can determine an appropriate step size -- small enough to catch each detail in good focus while still getting only 20-30% overlap between in-focus portions from step to step. At 30X with an adjustable aperture lens, I suspect that something around 0.005 mm will turn out to be reasonable, maybe even larger would be OK.
An easy way to run the test is to shoot a short stack of say 50 frames at 0.001 mm, then process the stack multiple times using every frame, every 2nd frame, every 3rd frame, and so on until you start losing detail and getting focus banding. In Zerene Stacker, there's a control for "Stack every N'th frame" at Options > Preferences > Preprocessing. You can check that box and adjust the number between runs of Stack > Align & Stack All (PMax). Or you might find it simpler and more reliable to run ZS multiple times, each time loading in just the subset of images you want to process in that run.
| Quote: | | When I uploaded the jpeg it went darker than original |
This sounds like a color profile issue. At this stage of the game, you'll be better off to stay in sRGB throughout your workflow. That will minimize surprises. If you're shooting JPEG in camera, then check the camera settings. If you're shooting raw and converting with DPP, then check under Tools > Preferences > Color management tab.
--Rik |
| Back to top |
Joined: 01 Aug 2006 Posts: 4067 Location: Issaquah, WA USA
Posted: Wed Dec 28, 2011 12:08 pm Post subject: |
Bob,
I think I have an idea about the primary cause of your problems, but need some more info about how you are set up.
I think you are using the Leica Z-16 (not X16) zoom system, is this correct? Which main objective are you using? ( 0.5X, 0.8X 1X, 2X or 5X? I am not referring to the zoom setting, but the objective itself).
The 1X is, by far, the most commonly used. If this is what you have, then the numerical aperture (NA) of your equipment will range from 0.017 to 0.112.
You said that your image was taken at 30X. Is this actually a 30X magnification on the camera sensor? This is very important information! (How are you determining the magnification?)
If (note the big "if". I am making some suppositions here that you need to confirm or change) your magnification on sensor is 30X, and you are using the 1X main objective you will never get a critically sharp image. Nothing to do with the quality of the equipment, but completely due to the fundamental physics of light. (The Leica Z6 Apo and Z16 Apo are about as good as it gets quality-wise, but they still come under the limitations of physics, and need to be used within certain magnification parameters for best results).
To obtain good resolution at a magnification of 30X (on APS-C sized sensor) you need to have a NA of about 0.50 (somewhere in the 0.40 to 0.60 range). With a maximum NA of 0.112, the on sensor magnification should be about 5X . Anything above 6X (on sensor) will suffer quite severely from resolution loss due to diffraction.
Edited to add a few additional thoughts:
| Quote: | | Maxillary Palp 30X at 793 slices and 0.001 mm with alignment turned off. | Even if you really are at 30X on sensor you are making far more work for yourself than needed. I think you have, at the very least, about 3X as many images as you need in the stack (even if you were using the 5X Apo that has a much larger NA).
Is the StackShot moving the subject or the macroscope? Unless things are extremely well aligned, I am not sure it is a good idea to turn off all alignment... I think it would be best to keep at least the x/y shift. (Rik would likely have a better opinion on that). _________________ http://www.krebsmicro.com |
| Back to top |
MacroB
Posted: Thu Dec 29, 2011 3:27 am Post subject: |
Hello Rik,
Not quite as bad as it sounds. I undid the front lens which is 71/2" long and since it came in sections that I had to put together, the lens was one such piece.
What do you think about turning off all the alignment in ZS's Options?
I find it cuts out the "Bar code" at the edges and stops the dust spots developing into curly hairs. Should I perhaps leave the X & Y shift checked?
Bob
Hello Charles,
Forgive my senior moment - it is, as you stated, the Z-16! I have the
Z-16 2.0x objective. Have not seen the numerical aperture mentioned anywhere, in fact, Leica do not give out much info. I find it best to write direct to Germany.
My measurement of Magnification was not exactly scientific since I used a macrometer and photographed the jaw space, when of course I had to include a tiny overlap.
FOV as measured 0.7 mm, size of image sensor 22.3 mm ÷ 0.7 = 31.857.
So, what is going to be the optimum aperture and what is the max pin sharp image size that I can hope to achieve? I remember in one of the adverts Leica mention adding a microscope objective to the front lens of the Z-16 to achieve even greater magnification.
If I reduced the magnification and added such an objective with its smaller size glass and presumably aperture, would that give me sharpness at 30x ?
Bob |
| Back to top |
Posted: Thu Dec 29, 2011 11:37 am Post subject: |
| Quote: | | Have not seen the numerical aperture mentioned anywhere, in fact, Leica do not give out much info. |
There is a mention in one brochure. (Why they used 40X eyepieces in this chart I have no idea. I've never seen anyone use 40X eyepieces. In any event, that does not change the numerical aperture):
So at full zoom, with the iris aperture fully open, you will have a NA of 0.224. This is far better than with the 1X but still not sufficient for the on-sensor magnification of 30X. With this objective (the 2X) it would be best to keep the maximum magnification, on an APS-C sensor, to about 8-10X. (At 8X you would already see some diffraction losses, but it should look pretty good).
One way to contemplate the upper magnification limits, (for photography on an APS sized sensor), when you know the microscopes NA, is to have a look at the numerical apertures of "typical" microscope objectives. Obviously this is a simple rule-of-thumb, but you can't go too far wrong using it.
4X and 5X... the NA is about 0.10 to 0.13
10X... the NA is generally in the 0.25 to 0.30 range
20X... the NA is generally about 0.40
40X... the NA is typically about 0.65 (but less for longer working distance models)
And if you look at the high-end fluorites and Apos you will find considerably higher NAs than this, with resulting higher resolution.
Leica does offer, for use with these systems, two objectives than can be used (in place of the 1X or 2X). These are the "HR 10×/0.45 and HR 20×/0.42", with working distances of 19mm and 13mm respectively. (I saw one note that mentioned they need to be used with the "higher" zoom settings... but it did not say what exactly those were). I can find no other info on their usage, so you would need to contact Leica or find someone that is familiar with them. If you decide to go that route, be sure to find out the image size the system will produce. I have seen similar arrangements that were essentially made to "cover" sensors much smaller than the APS-C size. (BTW this is the only Z16 system chart I have seen that shows DM objectives being used. These are seen in the brochure for the inverted microscope Leica DM IRB & DMIRM. The ones shown here are 10/0.25 N Plan and 20/0.40 N Plan L, both have M25 threads).
What follows is pure guessing on my part so take it as such!
The HR objectives appear to be infinity style microscope objectives and that the Z16 zoom component serves as a variable "tube lens". (I am basing this on the inclusion of the two "infinity" DM objectives in the above chart). Leica uses a 200mm tube lens for their biological microscopes. As such I strongly suspect that you could use use the adapters and select from a variety of other infinity objectives. (Nikon also uses an M25 thread and aq 200mm tube lens). I am a little puzzled in that my understanding is that Leica does do some optical correction with the tube lens in their biological stands, so I am not sure how that all sorts out here. However, if it did work, it would make for some interesting possibilities.
______________________________
I am pretty sure that the excessive magnification (for the available NA) is the primary cause of the image "softness" you are seeing. But a couple of other things you mentioned also raised a caution flag in my mind:
| Quote: | | Certainly when I was focusing and viewing on camera LCD all seemed sharp |
It might be worth considering whether or not there is any tiny subject or set-up movement due to the "blast" of a fairly powerful studio-type electronic flash. I have experienced this with certain set-ups when I used a Buff White Lightning unit. There was a posting on the forum not too long ago discussing this phenomenon. To check you could compare a flash image to one taken using only the modeling lights as the light source (camera set to live-view, silent mode on). _________________ http://www.krebsmicro.com |
| Back to top |
Posted: Thu Dec 29, 2011 12:40 pm Post subject: |
| MacroB wrote: | What do you think about turning off all the alignment in ZS's Options?
I find it cuts out the "Bar code" at the edges and stops the dust spots developing into curly hairs. Should I perhaps leave the X & Y shift checked? |
There's no ironclad rule here -- it's a matter of tradeoffs. See http://www.photomacrography.net/forum/viewtopic.php?p=79878#79878 for some discussion.
At 10X and above, I often turn off everything. If there's a bit of lateral play in the setup, leaving X and Y shift checked might work better. That's the way I shot the Noctua pronuba proboscis at 40X HERE and HERE.
By the way, those 40X images are using an ELWD objective with NA 0.50 . They're pretty good for this magnification, but I wouldn't consider them even close to "pin sharp" when viewed at actual pixels.
The reason for this is diffraction -- NA 0.50 at 40X corresponds to effective f/40 on the camera side.
The formula is just:
effective f-number = magnification / (2*NA).
With your objective at 30X and NA 0.234, you're looking at an effective aperture around f/64. That will be pretty blurred at actual pixels, but it should show a lot more detail than we can see in the 350x233 image that you've posted at the top of this thread. If it doesn't, then something else is going bad.
--Rik |
| Back to top |
MacroB
Posted: Fri Dec 30, 2011 5:35 am Post subject: |
Hello Rik and Charles,
Thank you both very much for all the info and your time, which is much appreciated.
Have started experimenting with the "stack selected frames" in ZS - something which I had previously not used. Will also try varying the alignment.
Before I bought the Einstein I had read about the blast moving the subject, so I did check when I first got it and all seemed ok. Must admit though that I was looking for movement on a larger scale, plus using a polystyrene cup as diffuser I thought all would be well.
I just had not thought of the blast from the studio flash moving the whole set-up or showing up as a more subtle movement! I am going to try the 30x shot using the MT-24EX and the 430EX II flash guns.
If that gives me a sharper image all well and good, if not I will see what Leica can suggest.
Thank you all once again and all the very best wishes for the New Year.
Bob |
| Back to top |
Posted: Fri Dec 30, 2011 1:45 pm Post subject: |
Bob,
I suggest doing the comparison using Einstein 640 flash, and them with the exact same set-up, using only the modeling lights (live-view. silent mode) for a comparison. That way you really have a direct comparison with same lighting angles. The flash would not cause vibration the entire set-up, but possibly with a more "gossamer" subject such as a butterfly wing (or perhaps the cup you are using for diffusion). In your case I really doubt this is the problem, but it is certainly worth checking, and it is easy to do so. _________________ http://www.krebsmicro.com |
| Back to top |
