www.photomacrography.net :: View topic - Two-part Zeiss articles on "How to Read MTF Curves"
Post new topic   Reply to topic    www.photomacrography.net Forum Index -> Macro & Microscopy Articles
DQE
PostPosted: Sun Dec 25, 2011 10:56 am    Post subject: Two-part Zeiss articles on "How to Read MTF Curves" Reply with quote
I generally have reservations about most published lens MTF curves since they usually aren't documented as to being theoretically calculated vs measured. Also, if measured, were they measured by a specific method or recognized standard? Interpretation is also a challenge since these data for lenses are usually complex curves in tangential (aka radial) and sagittal (aka meridional) directions. And then they are functions of the lens aperture, wavelength, etc. Still, with experience and understanding, the curves should describe image blur due to light spread in the lens in great detail.
Anyway, below are links to a two-part Zeiss article set on "How to Read MTF Curves":
Part 1 is linked first, then Part 2:
http://www.zeiss.de/C12567A8003B8B6F/EmbedTitelIntern/CLN_30_MTF_en/$File/CLN_MTF_Kurven_EN.pdf
http://www.zeiss.de/C12567A8003B8B6F/EmbedTitelIntern/CLN_31_MTF_en/$File/CLN_MTF_Kurven_2_en.pdf
(I suspect these documents have been posted and linked previously but I was unable to find previous posts via a simple forum search.)
-Phil
"Diffraction never sleeps"
l2oBiN
PostPosted: Fri Feb 13, 2015 6:42 am    Post subject: Reply with quote
Hi guys.. the links seem to be dead now...
PostPosted: Fri Feb 13, 2015 7:24 am    Post subject: Reply with quote
I was able to download them from a Google search , first two links returned, on "How to read MTF Curves Zeiss".
First link is
http://www.google.co.uk/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0CCMQFjAA&url=http%3A%2F%2Fwww.zeiss.com%2Fcontent%2Fdam%2FPhotography%2Fnew%2Fpdf%2Fen%2Fcln_archiv%2Fcln30_en_web_special_mtf_01.pdf&ei=2AbeVNnJEMPOaIGhgIAJ&usg=AFQjCNEXUHr22cTBpahS586luW_vqt1Opw&bvm=bv.85970519,d.d2s
Second is
http://www.google.co.uk/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&ved=0CCsQFjAB&url=http%3A%2F%2Fwww.zeiss.com%2Fcontent%2Fdam%2FPhotography%2Fnew%2Fpdf%2Fen%2Fcln_archiv%2Fcln31_en_web_special_mtf_02.pdf&ei=2AbeVNnJEMPOaIGhgIAJ&usg=AFQjCNGT9MZ6t0ccXpBMcxQfe8yu-sjvBA&bvm=bv.85970519,d.d2s&cad=rja
I've never worked out how to get the direct link from the result of a Google search when it's a download Confused
Quite a good article, covering Nikon, Canon and Zeiss charts:
https://photographylife.com/how-to-read-mtf-charts
PostPosted: Fri Feb 13, 2015 9:51 am    Post subject: Reply with quote
The target URL is buried in the middle of the Google query, between "url=" and the next "&", and with all punctuation represented in %hex notation.
Parsed out, these are:
http://www.zeiss.com/content/dam/Photography/new/pdf/en/cln_archiv/cln30_en_web_special_mtf_01.pdf
http://www.zeiss.com/content/dam/Photography/new/pdf/en/cln_archiv/cln31_en_web_special_mtf_02.pdf
Post new topic   Reply to topic    www.photomacrography.net Forum Index -> Macro & Microscopy Articles All times are GMT - 7 Hours
