www.photomacrography.net :: View topic - SPIDERS No. 33 – Spinnerets Part 2-Silk Spigots
Walter Piorkowski
PostPosted: Fri Dec 23, 2011 9:24 pm    Post subject: SPIDERS No. 33 – Spinnerets Part 2-Silk Spigots Reply with quote
Leitz Ortholux microscope
4X Leitz projection eyepiece plus 1/3x relay lens
Image No.1
Image of right side single posterior lateral spinneret and both posterior median spinnerets, at center. The anal tubercle is also visible (bottom).
Reflected diffused fiber-optic illumination.
52 images at .001 inch increments, Leitz UO 6.5x Achromat
Image No.2
Details of single, right side, posterior lateral spinneret. Note that silk gland spigots are being resolved.
Reflected diffused fiber-optic plus EPI illumination.
135 images at 5 micron increments, Leitz UO 11x Achromat.
Image No.3
Extreme close-up of right side, posterior lateral spinneret showing details of silk spigot structures from which the silk strands emanate plus an unidentified feature (top center).
Straight EPI illumination through Leitz Relief Mirror Condenser.
192 images at 1 micron increments, Leitz UO 23x Oil+W Apochromat.
Image No.4
Close-up of left side, posterior lateral and posterior median spinnerets showing details of hundreds of silk spigot structures from which the silk emanate.
129 images at 5 micron increments, Leitz UO 11x Achromat.
Image No.5
Extreme close up of left side, posterior lateral spinneret showing details of silk tube structures from which the silk strands emanate plus two unidentified features (top right).
162 images at 1 micron increments, Leitz UO 23x Oil+W Apochromat.
Canon 50D
Zerene PMax stacking.
Processing in Photoshop and Bibble Pro 5.
Walt
PostPosted: Sat Dec 24, 2011 1:24 am    Post subject: Reply with quote
Simply wonderful Walt!
PostPosted: Sat Dec 24, 2011 3:33 am    Post subject: Reply with quote
The images are fantastic. Is that new silk coming out of the spigots, or does she make hollowcore strands? I wonder how she grabs a new strand every time?
PostPosted: Sat Dec 24, 2011 4:37 am    Post subject: Reply with quote
Excellent!
Walter Piorkowski
PostPosted: Sat Dec 24, 2011 2:40 pm    Post subject: Reply with quote
Thank you Rogelio and Charles. Also Charles, congratulations on your Olympus Bioscapes win.
Mitch No silk is visible in any of the images, but any one of the hundreds of spigots will be producing strands simultaneously.
Walt
PostPosted: Sat Dec 24, 2011 3:58 pm    Post subject: Reply with quote
Wonderful!
Intrigued by
Are you using oil, or...?
curt0909
PostPosted: Sat Dec 24, 2011 7:56 pm    Post subject: Reply with quote
Very interesting structure and well done presentation. Somehow I've never thought to look at one... Last year I read an article that comes to mind after seing these photos. Scientists had successfully created a spider/goat hybrid(it was only one gene from spider). The resulting goat produced the protein that spider silk is made of in its milk. After extracting the spider silk from the milk they would form strands from a synthetic spinnerette. The problem was the synthetic spider silk was only 10% the strength of genuine spider silk.
PostPosted: Sun Dec 25, 2011 1:17 am    Post subject: Reply with quote
This really is an admirable study of a fascinating subject. Much patience and skill must be required. I am particularly interested in the use of the Leitz incident light attachment which I own, and don't use as often as I should.
Walter Piorkowski
PostPosted: Sun Dec 25, 2011 9:44 pm    Post subject: Reply with quote
Thank you gentlemen.
Chris, you are perceptive to note the proper usage of the 23x objective. I am employing an oil that at this point I will keep proprietary. I do a lot of experimenting and rule breaking.
Curt, when you do start looking at low magnification, like a stereo dissecting scope you sort of get hooked. However it seems like a well done stack is the only way to appreciate the complexity revealed by higher magnification. If your interests lie in a more scientific area of the subject, look up "Spider Silk" by Leslie Brunetta and Catherine L Craig. Craig is evolutionary biologist and provides an intensive study.
Dave, this study consumed several months of my limited "play" time, so I appreciate your acknowledgement of such. My experience with the EPI equipment is similar to yours in that I don't use it as much as I should. I also find it more pleasing as a visual vs. photographic device. However if the harshness of the direct EPI illumination can be softened or even mixed it can provide, as you see, some pleasing results.
Walt
