Gradient Universal Filter - 'DIC', DF, OL effects
Every 30 days the site administrators will pick an image made through a microscope from the "Photography Through the Microscope Gallery" to be featured on the front page of the www.amateurmicrography.net website.
Litonotus
Post by Litonotus »
Admin says: This post is now over 10 years old and the thread contains a lot of discussion spanning at least 4 pages. Please read the whole thread before posting more.
the quality is 'so so', but this is all I'm able to do now. All are taken using my Gradient Universal Filter that allows me to adjust both contrast and background brightness.
water flea (4 image 'hand made' stack)
water fleas (put together in PS)
rotifer - 4 images put together in PS
Jan l'Amie
Post by Jan l'Amie »
Great pictures. Very nice detail.
Byomic BYO500T microscope /CIOC XDS-1 invert.
Byomic ST-340 stereomicroscope
Olympus BHM Metallurgical Microscope
Canon EOS 7D Mark II / Canon MP-E65
Cognisys StackShot
www.ngvm.nl
Very nice!
Very good!
Please show us your magical DIC like filter and how to use it.
Chris_M
Post by Chris_M »
Very nice set!
Chris
Litonotus
Post by Litonotus »
thank you (:
it is not magical, it only required months of experiments.
it looks like this:
it is made of a grey gradient printed on a trasnparent foil, all fixed with black masking sticky foil.
and how it is seen through the eyepiece:
It is placed under the condenser between its bottom and the filter tray, and this placement allows the XY movement.
I have no possibility to take better images, but this filter provides a big number of effects: obligue light, 'DIC like' effect and even darkfield which I can't show here because my 'technique' of taking images makes it impossible for the camera. It works great with 5x, 10x and 20x objectives, on higher magnifications it gives only obligue light.
Post by Wim van Egmond »
Very nice results. I wonder if this technique works better than the one described in Jan's posting.
Wim
Many thanks, Linotus
It's a very interesting device.
Jan l'Amie
Thanks, a very nice idea for a new filter experiment to me.
Greetings
Jan
Cognisys StackShot
www.ngvm.nl
Litonotus
Post by Litonotus »
thank you all (:
Wim van Egmond wrote:Very nice results. I wonder if this technique works better than the one described in Jan's posting.
I think it works better because it is universal - there is only one filter that gives many effects on at least 3 different magnifications (: I'm sure it is possible to modify this idea to be much better.
I added a filter comparison below. I like better the grey one, but the blue gives visually more attractive images.
10x plan PZO objective
20x PZO achromat objective
My friend, very interesting and innovative solution, very nice photos
The result is very nice. The nice thing about your design is that it is simple to make. Only that gradient is a bit of work.
I wonder what would happen if you would use a polarised filter instead of the gradient. The polar filter where the gradient area is, leaving an open space above it for the direct light. With another polar filter you can make the filter darker (by rotating it) I think it will act like the gradient. I 'll try to find time to try it. Thanks for posting this Litonotus. It is a long time since I used these techniques and I am curious how your method works.
Wim
Litonotus
Post by Litonotus »
thank you Jacek (:
Wim van Egmond wrote:Only that gradient is a bit of work.
just print it on a transparent foil, that's all. every basic graphic program makes gradients. I use illustrator for that.
write about your trials.
Post by Mitch640 »
And just where on your microscope does the filter go?
Litonotus
Post by Litonotus »
Mitch640 wrote:And just where on your microscope does the filter go?
Litonotus wrote:It is placed under the condenser between its bottom and the filter tray
