www.photomacrography.net :: View topic - Rotational stage FOUND
Post new topic   Reply to topic    www.photomacrography.net Forum Index -> Equipment Exchange
johan
PostPosted: Mon Nov 14, 2011 3:47 am    Post subject: Rotational stage FOUND Reply with quote
Before I go looking on ebay, does anyone have a rotational stage with coarse and fine movement options that they want to get rid of?
Thanks
Perl
PostPosted: Mon Nov 14, 2011 7:54 am    Post subject: Reply with quote
Hi
Wonder Rotating Pol table ?
UT multi Axis ?
Might have what you look for - but its not for free
Regards
Pär
****** Seeing is Beliving ******
johan
PostPosted: Mon Nov 14, 2011 9:46 am    Post subject: Reply with quote
Not sure what you mean by those... I'm looking at spending about £150 on a newport rotating stage which has coarse and fine movement, has a 20cm diameter or so - that sort of thing
Perl
PostPosted: Mon Nov 14, 2011 10:29 am    Post subject: Reply with quote
Hi
Ok - Then i can not help you
Regards
Pär
johan
PostPosted: Mon Nov 14, 2011 1:17 pm    Post subject: Reply with quote
Okies thank you
Craig Gerard
PostPosted: Mon Nov 14, 2011 8:47 pm    Post subject: Reply with quote
johan,
Why a 20cm diameter?
A quick eBay search using "newport rotation" as the search criteria returns a number of items. Is there anything among those offerings that would fulfill your requirements?
johan
PostPosted: Tue Nov 15, 2011 2:44 am    Post subject: Reply with quote
20ish, 15ish - anywhere around there. Bottom line it has to fit on top of my lifter thing so that I can use that to rotate a cage thing I have yet to build, in which to have the creature so it doesn't fly away.
Those newports are exactly what I was looking at, but I just posted it here to see if someone had one they wanted to offload. Keep it in the family as such.
Post new topic   Reply to topic    www.photomacrography.net Forum Index -> Equipment Exchange All times are GMT - 7 Hours
