www.photomacrography.net :: View topic - Geranium petal veins in frontlight & backlight
PostPosted: Mon Nov 07, 2011 3:42 pm    Post subject: Geranium petal veins in frontlight & backlight Reply with quote
This a small section of the petal of a geranium flower, backlighted.
Same section, front lighted.
Alternating between the two:
The entire petal:
I was intrigued that a large contribution to the apparent "darkness" of the veins is just that they're transparent. When lighted from the front, more light goes through the vein and escapes out the rear instead of bouncing back like it does in the white part of the petal. Towards the ends of the petals, the transparency combines with a red pigment to produce what I thought was an interesting effect.
Technical details...
The first two images are about 0.96 mm across the field, shot with Nikon CFI 10X objective on 200 mm tube lens (like HERE) and cropped to an interesting section. These are stacks, 50 images at 0.010 mm, mostly Zerene Stacker DMap with a bit of retouching from PMax.
The animation is from the same stacks, with just a small crop around the edges to correct for an accidental shift when I shot them.
The final pair is with Raynox DCR 250 on the same telephoto, single shots at f/22 (no stacking).
snic320
PostPosted: Tue Nov 08, 2011 5:12 am    Post subject: Reply with quote
Interesting!
Once again giving me more ideas..... Rolling Eyes
Wink
DQE
PostPosted: Tue Nov 08, 2011 4:08 pm    Post subject: Reply with quote
I think that frequenting this forum has caused me to see stacking opportunities where there may be none:
Is there any benefit from some sort of stack or blend of the front and back-illuminated photos?
As usual for photography, there are two basic criteria: aesthetic and informational. In terms of information, not everything that is naturally separate should be combined! But sometimes it helps.
As usual, just some early evening musings...
-Phil
"Diffraction never sleeps"
Craig Gerard
PostPosted: Tue Nov 08, 2011 4:41 pm    Post subject: Reply with quote
Inverting the images also provides an interesting result Cool
madmacro
PostPosted: Wed Nov 09, 2011 5:17 am    Post subject: Wow. Reply with quote
Beautiful color, love the pattern and color combination,
Could have miss all this if you have not share, thanks Rik.
PostPosted: Thu Nov 10, 2011 12:03 am    Post subject: Reply with quote
Thanks for stopping in, folks.
snic320, I'm definitely looking forward to seeing some of those ideas. Cool
Phil, what did you have in mind? There are definitely some interesting effects you can get by dynamically blending from one to the other. The hard flashing transition that I'm showing here is just what's easy to do with gif.
Craig Gerard
PostPosted: Thu Nov 10, 2011 1:56 am    Post subject: Reply with quote
PS layer blend modes....enjoy Smile
PostPosted: Thu Nov 10, 2011 1:59 am    Post subject: Reply with quote
Craig, feel free to post some examples of what you're alluding to.
PostPosted: Sat Nov 12, 2011 6:47 am    Post subject: Reply with quote
Very very cool!
Canon 30D | EOS Rebel 2000-film(aka EOS 300) | Panasonic FZ-7 EB | Vivitar/Cosina 100mm f3.5 macro lens | EF 75-300 f4.5-5.6 USM III | EF 50 f1.8 II | Vivitar Series 1 19-35 f3.5-4.5 | Slik 88 Tripod. | My new blog:
http://mybackyardsafari.blogspot.com/
View user's profile Send private message Visit poster's website MSN Messenger
