See if you can guess the technique for capturing this bee sticking its tongue out in a flower. It's pretty deep for a single shot. On the other hand, how could one stack a shot of a bee while it slurps nectar? The only thing I'll say is that it is only slightly cropped at the top and bottom, maybe 10% off at each end.
Bee in flower
Wow, that took you what . . . 2 minutes? Nice job.
Here, Auto Tone brightened it up a little bit:
I was disappointed in the lack of detail. Can't see the facets in the eye nor the ocelli. I tried to make a light box out of a white styrofoam packaging box and hoped the light would bounce around inside, but there were really bad shadows that I couldn't get rid of. I'll keep playing.
"Nothing over 229" meant that when I pulled the image into Photoshop and looked at its histogram, there were no pixels with a value greater than 229 out of a possible 255. That means you're giving away 10% or so of your brightest values. That's not necessarily wrong, it just means there's an opportunity to lighten up even the areas that are already the lightest.
Regarding lighting, search the forum for NikonUser's various postings regarding white plastic foam cups. (They might be indexed as "styrofoam". I don't remember for sure.) He gets great mileage even from just a single flash, with a foam cup shaped and positioned so that the toward-light side of the subject gets lit by flash diffusing through the front side of the cup, and the away-from-light side of the subject gets lit by flash bouncing off the back side of the cup.
Sorry about figuring out your trick so fast. I just happened to be on the forum when you posted, and I've seen a few of these before -- including in front of my own camera. Check out this spider.
Tips:rjlittlefield wrote:Dead bee, propped by its wings and tongue. Nicely done, though!
Bees have their wings folded over their abdomen when feeding, rising slightly as the bee bends its head down to insert its tongue. They also have their legs extended.
That said, a nice result for what it is.
Harold
