http://www.photomacrography.net/forum/v ... 6946#66946
So I thought it might be interesting to continue the topic in a new thread.
Humm, that seems pretty low for a minimum pulse duration. Were these Cree XP-E LEDs? Wired in series or parallel? I’m pretty sure I could get pulse durations shorter than 1/2000 sec using a Cree MC-E LEDs, which is a quad unit (essentially four XP-E type emitters in one lamp). I drove them in series up to about 2 amps (each chip is rated at 700 mA max, continuous) for 0.5 ms and looked at the output using a fast avalanche photodiode connected to the o’scope. Based on the rise/fall times, I think it would have been possible to go shorter. I know that most single wavelength LEDs can be switched at below 1 uS, limited by the ESR and chip capacitance. But I’ve read that some of the high power white LEDs are limited by an “after glow” effect from the phosphor coating used over the base blue or UV emitter. I’m sure you noticed there is not much info on the net about this stuff. So it’s pretty much, try it and see.AndrewC wrote:LEDS: even knocking a 6 amp pulse through 3 emitters I can't drop to 1/1000" pulses which is what I want for "flash" illumination.
In terms of achieving proper subject exposure, I think your goal of 1/1000 sec is doable (but borderline), depending on the number and peak power of the LEDs and the optical coupling efficiency. One huge advantage of flash over LEDs is that even small flash tubes typically produce thousands of times more peak light output than the current lot of high power LEDs. Here’s a link to an older post on CandlePowerForums regarding the issues of using LEDs for high speed photo flash (they do not discuss macro use and newer LEDs now have a few times higher power outputs, but the relative magnitudes of LED vs flash power output are still valid):
http://www.candlepowerforums.com/vb/sho ... p?t=121144
To determine what’s possible under optimized conditions, I’ve tested several LEDs in continuous mode using efficient parabolic reflectors that will focus most the light down to about a 10mm spot and made meter reading off of an 18% gray card using a macro lens at an effective aperture of f16. The Cree MC-E running at full rated power (700mA continuous per emitter) gave a correct exposure at 1/1500 sec. Add on layer of white Kleenex tissue over the reflector dropped the meter reading for correct exposure two stops to 1/375 sec. Given the expected coupling losses incurred using a FO cable (I haven’t tested this) the required exposure time will be lower---let’s say 1 stop, so 1/180 sec.
Therefore, it would require about 5.5 MC-E LEDs to allow a 1/1000 sec exposure. If you can pulse the LEDs at much high current to get let’s say 3x the light output, then you could possibly get to 1/1000 sec with two quad-emitter MC-E LEDs or 8 single XP-E LEDs.
I’m toying with an, AFAIK, unique idea (or more likely, I just haven’t found it in my searches) to improve the results, which I think has some potential (but not yet tested). Surround the macro subject with 10 to 20 LEDs in a spherical shape directed through something like Charles’ pingpong ball diffuser. A very large heatsink would be necessary to cool this thing to allow running all the LEDs at full power---maybe requiring water cooling or heat pipes. But that shouldn’t be necessary. For modeling, they could be run at a friction of the rated power and still provide plenty of light. Then, pulse them at high power for the exposure. Another interesting possibility would be to wire each LED (or groups of LEDs), separately, to individually adjustable current sources. This would allow for “custom” programmable illumination and shadow effects, in order to enhance structures on each specific subject!
Also, the previously mentioned issues with the non-blackbody color spectrum of many LEDs can be successfully dealt with by using high-CRI (Color Rendering Index) LEDs (CRI up to 93) and/or by using Adobe’s DNG Profile Editor to create custom color correction profiles that can be used in Adobe Camera Raw or Lightroom to normalize the spectrum.
If anyone sees flaws or issues in any of these concepts, I welcome critiques. That’s what I find so valuable about this forum.
More ideas, comments?
Bob
