My first contribution - Anthidium florentinum
This is my first contribution to the forum, it's a bee known as Anthidium florentium.
The photo had been taken with a Sigma 105mm Macro lens, using all three macro extension tubes. I also used the Sigma macro flash EM-140.
Always learning
A good clear shot with a very similar set up to mine lens-wise.............but I think you need to devise a diffuser to soften your flash...............better experts than me on here will advise further:
Like many others I fitted an opaque plastic container over the flash head....lined it with crinkly cooking foil then covered it all with a double layer of opaque A4 folder.........I will see if I can find a photograph for you:
Here you go............there is now an opaque plastic folder wrapped around to diffuse the flash even more...............my current favourite settings are
F16 or F14 S 160 with the flash level adjusted to suit ambient light conditions...............see my latest posts for results:
I hope this helps?
sonyalpha
For illustration, see here:
http://www.photomacrography.net/forum/u ... ORUM_2.jpg
http://www.photomacrography.net/forum/u ... ORUM_1.jpg
I hope this helps?
sonyalpha
Retired but not old in spirit:
Fairly new to photography........keen to learn:
rumbert, welcome aboard!
The bee looks good. Interesting composition, focus placed perfectly, good control of both highlights and shadows, creamy background. Nicely done!
The eye would look a little more natural with more diffuse illumination, but it's hard to keep two flashes from producing separate reflections no matter what you do. Many people use a single-flash scheme with a large diffuser to sort of imitate overcast lighting. The snoot arrangement shown in sonyalpha's setup does something similar.
Don't know about the EM-140 but on my 430EX Canon speedlite, I use a rectangular piece of plastic cut from a frosted water jug and it is held in place with stick on velcro strips. That way I can remove or replace the diffuser quickly as needed. It is flat, easy to stow in your gadget bag, and doesn't take up space, if any, at all.rumbert wrote:Thanks for your comments.
Do you know any configuration schema to apply a diffusor to the EM-140? Maybe overlapping a soft paper?
As a result of your lighting technique in this beautiful photo it appears that one can see through the surface of the eye to the bee's retina.
This has opened my eyes to a new way of thinking about how/what an insect sees. I have to admit that I thought a compound eye produces completely formed images at each facet that are sent from there to the brain where they are integrated as some sort of multi-image picture (as has been depicted in so many "Nature Shows").
It now seems apparent that each facet is part of a large lens which projects an image onto one large retinal structure and then to the brain, much as our eyes do.
This makes a lot More sense than my former way of thinking.
Please chime-in if you feel like enlightening me further.
Jim
Jim
- Tesselator
Excellent Bee.
And welcome in!
BTW, I don't think their brains are big enough to process shape - but if we could use their eye lenses to render the pattern that is ultimately transmitted to their brain I guess we could process the shapes. I guess it would look fish-eye like and pixelated.
http://www.isa.org/InTechTemplate.cfm?S ... ntID=53255
http://www.biology-blog.com/blogs/perma ... ision.html
And welcome in!
Wow! Both are very interesting and enlightening articles Tess. they do not address what I think I see in rumbert's fine photograph but on the other hand what I imagine to be retina may only be reflections of the bee's body.
Regardless this picture has inspired my to delve deeper into insect vision, make that vision in general.
See what you've started rumbert?
Keep shooting,
Jim
Keep shooting,
Jim
