Ah! I know those people.
If I recall correctly, that animation is true stereo. They shoot 72 stacks separated by 5 degrees (72*5=360), then assemble each neighboring pair of stacked composites to make 72 stereo pairs.
They were intrigued by the thought of using Zerene Stacker synthetic stereo to fill in the gaps, making a smoother animation from the same number of raw frames. A lens operating at f/8 on the subject side has an aperture that spans about 7 degrees, so at least for smaller subjects there should be enough data in each stack for that to work out OK.
By the way, when I wrote "moving in a circle", I was actually thinking of rocking up/down and side/side simultaneously, with 90 degrees phase shift. Think of sliding the optical axis around the surface of a cone.
